hey time for an oil change
my car just hit 72k and im getting ready for an oil change (synthetic) any recommendations? as well as the filter? other things i should look into working on as well? Thanks!!
Agreed, Pennzoil Platinum is the proven "bang for the buck" oil for the LSX tested on BITOG & here via UOA's. Although, I would suggest 5w30 even @ 72k miles.
Amsoil is also an excellent oil. It just costs more.
Here we go again... page 1...
I recently switched from M1 to Penzoil platinum. K&N filter is great because it has a 1 inch socket fitting on the bottom for easy install/removal. That is all.
royal purple has been proven to give you more power because of less friction. if you look on websites the only people that talk **** about royal purple are amsoil representatives.
lol....almost every brand of oil has been posted in the first 10 posts. This question is about like asking what's the best cam to buy. The answer is always whatever is running in the car of the person posting the answer. Just use a high a quality oil and filter with the correct weight and change it every 3-5000 miles. Don't lose any sleep over it and don't go broke doing it.
Thank you very much for your responses! Think im going to go with the Pennzoil 10w-30 with a K&N.
now, I've had the transmission fluid changed, anything else? hows about a radiator flush?
