cam with stock heads
Old Jan 18, 2009 | 11:49 PM
Ryan Armstrong's Avatar
Default cam with stock heads
does anyone know what is the best cam that will match up with stock heads
thanks
Old Jan 19, 2009 | 01:06 AM
krazy4's Avatar
It depends on what you want to do lol
Old Jan 19, 2009 | 09:12 AM
conan's Avatar
Get some headers and a intake manifold before you start to choose a cam.
Old Jan 19, 2009 | 09:15 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
What are you planning on doing with the car? Is this for the TA in your sig? What supporting mods? What are your goals for the cam swap in terms of power, driveability, sound, etc? Let us know some more info and we'll be able to make a much better decision on what would be the "best" cam for you
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jan 19, 2009 | 09:20 AM
Bizzles's Avatar
What your suggestions be for a semi-DD with my mods in sig, including the ones wtb installed??
THANKS!
Old Jan 19, 2009 | 09:27 AM
Jason 98 TA's Avatar
Bizzles look to a converter first if your thinking about anything bigger than a 224R camshaft. Personally with stock gearing & a verter size similar to what your thinking about buying the 228R or Torquer 3 would both be great options for your car. Give us a call sometime your free & we can send you over engine dyno testing we've done back to back with most of the popluar TSP camshafts!!
RyanDo you currently have any headers on your car?
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jan 19, 2009 | 09:34 AM
Bizzles's Avatar
Jason I currently have the verter, sorry my sig is confusing it's 'waiting' to be installed...lol have to fix that, thanks! I'll certainly look into both of those and give you a call!
Old Jan 19, 2009 | 11:19 AM
well about a week ago some jackass decided to try and u turn right in front of me and i had no where to go. the TA in my sig is now totalled but im pullin that motor to put in my 94 camaro. i want to do headers and cam while i have the motor out. looking to hit high 300 to low 400 hp
Old Jan 19, 2009 | 11:41 AM
conan's Avatar
Sorry to hear! I'd get some lt's and a ls6 intake with the TSP228R cam and you'll have your goal of high 300 low 400 hp.
Old Jan 19, 2009 | 07:54 PM
yea im going with pace setter long tubes and i was thinking that same cam
