ms4 cam, stock heads, can i raise the cp by using a thinner hd gasket. without flycut
Let me know what you think guys.. What is the thinest gasket I can put in to get the compression up a bit? Remember stock heads ms4 cam....
LS1Tech Premium Sponsor
The PRC 215 heads will give you smaller chambers & clearance for the MS4 camshaft. We recently had a customer make over 485rwhp with a smaller Tsunami camshaft & the PRC 215 heads. We can get you 59cc chambers & clear the MS4!!
http://www.texas-speed.com/shop/item...d=993&catid=40
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
