How about an LS7 Cam in a 383? Tired of the Sewing Machine Noise!!!
I would appreciate some advice regarding my 383 I recently built. I used an LS6 block, honed to match new Mahle 3.905" forged pistons, SCAT 4" crank and H-Beam rods. The heads are 243 castings, milled .020". I'm using Patriot Gold valve springs.
The problem I'm having is that despite trying several push-rod lengths, I still have that annoying "sewing-machine" sound from the engine. I tried 7.35", then 7.30" (much worse), and finally settled on 7.40". Since the heads were milled .020" and the block surface decked .008", I wouldn't think that any longer would be good for the LS1 lifters. I've tried measuring with the Comp Cams push-rod checker, but I just get more discouraged.
What I suspect is the cam lobes are just too aggressive, which is causing the valves to snap shut. The cam is a Comp Cams - 224 intake, 230 exhaust, .609 lift/.605" on a 114LSA. These are the XFI lobes.
What are the thoughts about going with a less aggressive cam like the factory LS7 cam? I know that I would need an LS2 front cover and cam sensor extension, but that's no problem. Would the motor sound stock again? Would the cam be sufficient for a 383?
Any other thoughts?
Any other thoughts?
LSX Mechanic
IMO it would be a complete and utter waste of your time and money to put a factory GM cam back in a 383 engine. Not too mention it takes some elbow grease on the LS2/7 conversion to use their cams. I've done the conversion once, and don't ever plan on doing it again. The gain wasn't worth it, nor what I got paid to do it.
Your main problem is the XFI lobe. If you backed down to an XE or XE-R lobe even, you'd notice a dramatic decrease in valvetrain noise. It won't be dead quiet, but will be noticeably quieter. One big reason I don't use LSK or XFI lobes is for this reason, that and their spring killers. Most of the cams I use are on XE or XE-R, and I've never once got a complaint on valvetrain noise.
How are you setting up the valvetrain? Are you using an adjustable pushrod, checking preload, using a checker spring, etc etc ? If you're just throwing diff. length pushrods in there hoping something will work, that's not how to go about it. Not trying to be a dick, just letting you know.
That cam choice could also be a tad better for your application. I use a 232/236 XE-R/XE 113+4 cam in the 383's I've done, and it's kicked major ***, the valvetrain is quiet
, and driveability is about perfect.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
As for the pushrod length checking, I tried using the pushrod checker, but it's kind of hard to tell if the lifter plunger is all the way pumped-up or down in the lifter body. Then, it's a pain the *** to keep putting the rocker back on, checking for movement, etc. I guess I'm just getting lazy (lazier??) in my old age.
But, I'd be open to another cam to quiet things down. I'm at the point were I really don't want to even drive the thing. It's embarassing. tic-tic-tic-tic-tic-tic-tic........
I think you have it backwards... my valve train noise is almost stock and I am running the same XFI cam. It's definately quieter than the XERs I've heard... not to mention it's easier on the springs, giving them LONGER life.
Even though you mentioned it already, my guess is either pushrod length or lifter preload. With this cam, Patrick G recommended 7.425, but I got away with 7.4. You might want to try the 7.425 if you can't get the lifter preload correct.
