Heads only questions
Pretty much what could I expect from bolt ons only with a set of ported LS6 or LS2 heads?
Would there be benefits to milling them to up the CR a tad?
Would you not touch the limiter since it would still be a stock cam?
What would be required tuning wise?
Any results out there with a similar set-up? Thanks!
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Going that far into the engine and not doing a cam isn't really relative. The heads are right there up top and require the intake and manifolds off, neither of which come off for a cam swap. Really the only part of tearing the car down for a cam swap that the heads would do is the prep of draining fluids and maybe the valvecovers to do springs.
Also maybe you didn't notice the car this was for. Heads are MUCH easier to do on a C5 vs. F-body with them buried under the cowl. Also a cam swap is much more involved on my car with the entire steering system needing to be dropped for it. Heads and an intake are in store for my car so the heads are RIGHT there where as a cam would still require a TON more work.
Hope this helps clairfy why. I appreciate the response though!
http://www.texas-speed.com/shop/item...d=649&catid=40
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
would make for some nice street friendly power, and proabably gobs of torque.
Even if its only a baby cam. Your going to make way more power and retain near stock driveability once tuned. Plus you know you liked how your TA sounded after you built the motor
Does sound sweet, but stock sounding with more power than one may expect is also cool! Plus a cam install on a C5 is a PITA
http://www.jrracingtuning.com/Russ.html
you put a ton of miles on the car as a daily driver and/or
if the shortblock has tons of miles on it.
My thinking is, to take this as far as it can go and retain 100k mile + reliability, heads, FAST intake, TB, lid, and exhaust are absolutely the way to go. Don't disturb the lower end if you don't have to. My dream combo would be the AFR 205s and the FAST 92/92. Don't listen to the guy who says a tune is worthless with the stock cam, he's misinformed. A GOOD tune regularly grabs 10-25 rwhp on stock/bolt on cars depending on how rich and off the stock tune is. That will only be more true with some good heads.
If you really wanted to go hog wild, Mamo-fy the heads, intake, sand and paint the intake black, use an 02+ LS6 cam/springs, get a good tune and you have the best of all worlds. 400/400 and stock manners/MPG/reliability. Stealthy killer. I put so many miles on my car, I don't want to change springs every year, which is why the stock/LS6 cam is something I have looked into.
I think you're on the right track with looking at a good ported, small runner head to maximize the stock short with no real downside. I'm curious how the new PRC 215s would do, as well as the AFR 205s. I'm surprised more people don't go this way. Some stage 1 or 2 GTP heads would be good for this too, as Craig's approach was always velocity throughout the range.
Keep us posted.
Jason
Keep us posted.
Jason
Looking at the GTO results now! Thanks for the post!
the car made with heads and headers added. Before them i already had 4.10's and a SLP loudmouth CB and MTI lid. Before the heads and headers the best E.T. i had was in the 12.7's then after the adding only the heads and FLP headers the car's best E.T. was a 12.08 @ 116mph with still using the stock '99 cam and the LS1 intake. The only tuning i had was a hypertech for the gears. So i guess the right heads can deliver gains when ported correctly.
Seriously, I would DIE to see what a ported FAST combo and ported AFR205s would do with a good tune on your stock cam. My guess is 400/400 and sound stock! Good luck!
There are AFRs that pop up here and on cf.com. Keep us posted on what you do!
, good luck with the swap and post up the results!
