Need Help about a 4.8 and 6.0 truck
It would be best if you got a 6.0 from a 2001-2006 model. The '08 has a different crank reluctor wheel, cam position sensor, and revised knock sensor location. The blocks are externally the same, so it would be a direct swap for the 4.8 otherwise. You also have the option to purchase an adapter module from LPE that will allow your 2001 PCM to control the 2008 engine, but I'd rather use the 01-06 engines myself.
