about to install CAM
Old Jan 31, 2009 | 11:02 PM
Greg Pippin's Avatar
Default about to install CAM
first off, my LS1 has 160,xxx miles on it.
i need some advice on installing my cam.
with that many miles do i need to remove heads.
Any advice will be helpful,
Thanks.
Old Jan 31, 2009 | 11:52 PM
Coppertop8705's Avatar
all new valve seals timing chain oil pump.
Old Feb 1, 2009 | 02:33 PM
396375's Avatar
Here's how to do it.Don't be afraid to post any questions no matter how simple.Good luck.
http://www.ls1howto.com/index.php?article=23
Old Feb 1, 2009 | 02:44 PM
Chrome355z's Avatar
I wouldn't pull the heads unless you were going to send them off to have a valvejob done. With that many miles that might not be a bad idea (or at least lapping them).
I'd do as above: New oil pump, timing chain, valve seals... Personally I wouldn't pull the heads unless I was going to put a different set on (ported 243/5.3 or aftermarket).
Old Feb 1, 2009 | 05:44 PM
FlashLCD33's Avatar
Pull the heads and install some LS7 lifters IMO. I put in a fairly mild cam (Torquer 2 - 232/234) on my car with 80k miles and had a lifter fail shortly after. Nothing is worse then being excited to drive your new cammed car and then having to tear it all apart again to replace a lifter.
That, and you also have a good chance to look at the health of the motor. At 80k miles, my engine still has hone marks in the cylinders with absolutely no scratching. The heads look nice as well. Just some reassurance that your motor is healthy and well taken care of.
Old Feb 1, 2009 | 05:48 PM
Chrome355z's Avatar
From what i've been told there is really no difference between the "ls7" lifters and the stock LS1 lifters. Probably went with a different supplier (maybe better). But most seem to say that it's the same as a stock lifter.
Now if you had 100k plus on the engine, it's never a bad idea...???
Old Feb 1, 2009 | 06:21 PM
FlashLCD33's Avatar
Even if you replace them with stock lifters, you're replacing worn lifters with new. You really can't lose.
Old Feb 1, 2009 | 06:23 PM
Chrome355z's Avatar
Agree.
Old Feb 2, 2009 | 07:38 PM
thinks for all the replys...
im replacing for sure: cam, springs, t-chain, and push rods...
i know i need the oil pump and lifters, unless someone has these items cheap im going to hope for the best??!!
Old Feb 2, 2009 | 07:45 PM
vsocks1's Avatar
I have a QTP performance oil pump like new - sells for $180 and I will sell it for $90 shipped! Also have new lifter trays that I would sell you for another $20 if purchased with the pump!
Old Feb 2, 2009 | 07:48 PM
lemons12's Avatar
if it were me i would only buy a new oil pump and timing chain... thats not something you want to go cheap on...
saving 20 bucks could cause you a huge headache and a lot of money..
Old Feb 2, 2009 | 08:01 PM
pm sent to vsocks1
Old Feb 2, 2009 | 08:16 PM
vsocks1's Avatar
pm sent to vsocks1
PM replied!
Old Feb 2, 2009 | 08:25 PM
received PM
Old Feb 2, 2009 | 08:26 PM
lemons12's Avatar
ok guys, PMs are going to be sent/replied.. we get it..
Im also looking for a t-56 for the same car>>>
Old Feb 2, 2009 | 08:30 PM
sorry...... ha ha.....
