6.0 truck engine build?
Old Feb 1, 2009 | 07:00 PM
peedeerooster's Avatar
Default 6.0 truck engine build?
Guys, I am building a 6.0 cast iron truck block to put in my truck. Does anyone know if there are any hyperueretic oversize pistons for the 4.00 bore that are flat tops. Like a 4.03 LQ9 or LS2 replacement piston. Thanks
Old Feb 1, 2009 | 07:58 PM
novaflash2002's Avatar
yes there is, contact gm and get the part number, and go on gmpartsdirect.com and get them for 1/4 the price
Old Feb 1, 2009 | 08:09 PM
devilsalmostfree's Avatar
thats right!
Old Feb 1, 2009 | 08:17 PM
KCS's Avatar
KCS
Moderator
I think Speed Pro makes hypereutectic pistons as well for LSx engines.
Old Feb 1, 2009 | 08:54 PM
This is an LQ4 pullout build. I had purchased LQ9 rods and pistons. I am boring to 4.03 and wanted to use the LQ9 rods and replacement flat top 4.030 pistons. I don't need expensive forged pistons because this motor will only be 10.9 to 1 compression and naturally aspirated running a 226/228 585/588 114+4 cam and going in the truck. Thanks.
Old Feb 1, 2009 | 10:25 PM
1FastBrick's Avatar
Yes speed pro Makes them They are the same exact Pistons for an LS2 Set up. Clemonsdave just did this over on the truck side...
SEALED POWER Part # H1129CT come in STD, .020 -.50mm, .030 -.75mm
he posted a Pic on page 6 about 1/2 way down. Here is the link...
http://www.performancetrucks.net/for...=431599&page=6
Old Feb 1, 2009 | 10:40 PM
Is that on the truck part of LS1 tech or the LS1 truck forum? If I could bore my cast block to 4.030 and use the LQ9 rods with 4.030 hyperpuretic pistons, that is want I want to do. I have a set of Patriot stage 3 heads with 2.08/1.60 valves and a vengeance VRX3 cam to put in it. That would be fine for my 2005 RCSB Z71 truck and probably be a good naturally aspirated budget build.
Old Feb 1, 2009 | 10:42 PM
1FastBrick's Avatar
Use the link I posted above. It is the truck side of this forum... AKA Performance Trucks.net Same user name an password work over there
Old Feb 1, 2009 | 10:44 PM
1FastBrick's Avatar
Here this is the specific post with the picture. You will probally need to login over there first before you can see the picture
http://www.performancetrucks.net/for...2&postcount=60
Old Feb 2, 2009 | 09:10 AM
Thanks for the help. Those pistons are exactly what I want to use with the LQ9/LS2 rods. May go just .020 for now, since they make those.
Old Feb 2, 2009 | 08:45 PM
1FastBrick's Avatar
Any time!!! The sales guys have no Idea what the diffrenece is
