Which heads compliment the TR224/114 best?
I have the older stg 2.5 5.3s _ TR224/224 @ 114 with UD Pulley,LTs,LS6 intake mani and put down :
![](http://i7.photobucket.com/albums/y287/OffspringZ28/01_SS_headcam.jpg)
currently chasing down an annoying tick that started shortly after that dyno. im thinking lifter.
TSP - How well do your Stg 3 LS6 heads flow? I might be looking to get those + a bigger cam as i won't have to flycut.
Thanks so much for posting the chart. Looks like the torque curve is nice and flat as mentioned above. Was this through a 10 bolt with the stock 3.42 gears? Lastly, what do you mean by the "older" 5.3's...if I purchased these tomorrow they would be a newer version? What is the difference?
I have a similar setup, and hit 400 (corrected) with the stock heads.
Graph: http://i85.photobucket.com/albums/k7...a_dyno_402.jpg
#33
you've got a ringer
