Tsp 233/239 cam
Within the next month I intend on buying pacesetter LT's, a TSP true dual kit, and a TSP 233/239 cam package. When I get the cam, what would be the best way to tune it? And how much will that cost?
Also, what kind of numbers will I be looking at after the exhaust and cam?
The exhaust will be dumped before the axles. Thanks for all the help guys.
-Lucas
I will be driving this car as a daily when summer comes around. Should I go with this or the 224/224 XE cam? Or possibly even the 220/220?
Also, do i need to spring the extra $110 for the PRC springs or will the 918 be good enough?
Thanks for all of the help guys.
As far as springs, I would suggest dual springs with a larger cam. That is just my personal preference and is easily debatable.
As far as which cam? Read the thousands of threads. My thoughts? Most people see a large cam listed for sale and want it. Bigger = Better in many people's minds. I think you would be happier with the 224 cam. However, I do not know you and do not know what you plan for your car.
Good luck. Hopefully someone with much more knowledge will chime in. I can answer the TSP 233/239 specific questions though
You'd need a 236+ intake lobe to justify pushing your shift point out that much... IMO
id go double springs, hardened pushrods, no rockers..
you have to have a stall before you get that size cam. only cam sizes you dont need without a stall is like a 218 or something..
btw, you will pick up more e/t getting a stall than getting a cam.. if you get a good stall... dont go cheap on the stall... Vig, Yank, Circle D is where its at.. dont get a TCI fuddle etc..
I have a streetsweeper HT and my peak power is at 6.9K....a bigger cam with a higher LSA I could easily believe making more power at 7.2K
That was an ls7 lifter that went bad I would recomend something better tha
Either way, get hardened pushrods, Ls2 timing chain set and an Ls6 oil pump, What lemons said...it's a must and besides, you're already down there anyways when doing the cam swap might as well...
Just ordered an LS6 intake today. So I'll have the full dual exhuast, ls6 intake, lid, and yank ss3600 stall. I figure I should be running 12's with that setup, yah?
