newb question on crank position sensor
Old Feb 5, 2009 | 08:13 AM
demonpixel's Avatar
Default newb question on crank position sensor
I installed my crankshaft position sensor this morning without even thinking about it, but now I'm getting a little paranoid...
I can't remember where I heard this, but someone had told me that a green o-ring on the crank position sensor meant it was for a 24x reluctor wheel, and a black o-ring meant it was for a 58x reluctor wheel. Is this at all true?
I have a 98 LS1 w/98 PCM, stock crank, but a black o-ring on my crank position sensor (it was the same one that I pulled off the engine during the teardown).
I should be ok right?? I'll do a search for what a stock reluctor wheel is for a 98 LS1 crank...
Thanks again for any help/advice guys
Old Feb 5, 2009 | 09:20 AM
Chris10an's Avatar
you are safe. red, black, gren, yellow. all same. *** long it's tighten good.
Old Feb 5, 2009 | 09:21 AM
Jon@Texas-Speed's Avatar
If it is a '98 crank, it has a 24x reluctor on it. As far as o-ring goes, I don't think the color will matter.
Jon
Old Feb 5, 2009 | 04:18 PM
demonpixel's Avatar
Good stuff, thanks guys. I got some weird info I guess. I feel better now.
