Questions about a MTI X1 set up..
Im finally getting around to putting my cam in I only bought it about a year ago, anyway Ive been looking at peoples comments and set ups I can find the exact answers Im looking for. I have the oil pump the chain the push rods. I already put the ls6 intake on. Currently I have pacesetter long tubes with a magnaflow catback and cut out, but I MAY switch to a GMMG. Id like to here it after the cam is in then put the GMMG on, reason being I dont want it extremely loud but I do want it to sound GOOD,and getting ready to put a set of 4.10s in.
What size injectors are a good combination to run with this cam, does the fuel pressure regulator need to be changed. If I got a set of 5.3 heads off a pick up, what would I need to do to them to make it worth it or is it not worth it just leave it cam only. If I was to get heads that would be the only way as of right now anyway. Basically Im looking to find my best combination. The car is only driven in the summer I wouldnt call it a DD but I try to take advantage of every nice day I can. Not going to be at any race tracks. It is a 6 speed. Im in NE Pennsylvania and realize im going to have to go down the line to get a good tune, all I know of is harris speed works and rapid motorsports, any others that are reputable in PA ?
Basically just trying to get pointed in the right direction for all the areas, my goal is to have it streetable, I dont need crazy power up top cause really there isnt anywhere to go that fast and I dont plan on going to a track, I would like to be as close as it can to 400 hp though
Thanks for any help!
Do you have all the supporting bolt-ons to help out the cam? If so, your 400hp mark shouldnt be a problem
My brother has the X1 cam in his '01 Z06. Of course he has stock 243 heads which you dont. But with the cam,full exhaust,intake,and predator tune he made 422rwhp/395rwtq.
As for exhaust, it sounds bad *** with straight exhaust but too loud for cops
He then muffled it down and still has a nice lope to it. Here are some clips:
This is with straight exhaust, no mufflers
http://www.youtube.com/watch?v=KOVwrvzNVPk
With dual magnaflow bullets (still kinda loud!)
http://www.youtube.com/watch?v=pZK5hiJ58H4
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Don't bother getting 5.3 heads off a pickup. In stock form they'll flow way worse than your current heads. Look for the cnc'd ones with bigger valves from prc. Or if you can't afford them look for some stock 243 heads for around $500.
The second clip is still with straight exhaust also at idle. But yeah The MTI X1 was a good cam and good for DD. You will like it. Hell if I had better heads, and a fast intake that number would be around 460-480 Easy!
Hey *** when you going to throw that 406 in the camaro? AFR heads, cammed, demon carb, that thing will wake up!
I dont know, thats pushin it
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
