metal in oil pan
metal in oil pan
checked the oil in the pan due to a slight knock after running at the track and the magnet had metal on it. enough to slow down the oil draining almost totally. the motor is a 365cu, 6.0 heads, weisco pistons 8:1 comp, carillo rods, ls1 crank. the motor has a couple passes on it at 11psi of boost. on the second pass off the t-brake the knock started. anyone have something like this happen? was the machine shop off? i built everything on the car except the short block. i was also running mobile 1 10w30, and a quart of lucas oil stabilizer. any help is appreciated.
thanks
thanks
The lucas oil stabilizer was a bad idea. You can't do it now because the engine bearings are trashed, but there is a way to prove it. Run your car to redline with the oil stabilizer then shut it down and drain the oil. The oil will be full of air bubbles. These prevent the oil from forming a boundary layer between the moving parts and allow the bearings to run against the crank. This stuff is very bad for gen 3 engines. I know three people personally that put this in their cars and developed a knock shortly thereafter.
Here is a good link testing the oil stabilizer: http://www.bobistheoilguy.com/images/lucas/lucas.htm
