f13 or f14
2002 Z28 Camaro A4 with Trickflow 215cc heads milled to 62cc, Harland sharp shaft roller rockers 1.7 ratio, 232/236-646/612-114LSA cam, FMS chrome-moly hardened 5/16" push rods 7.500", ARP hex head bolts, FMS ported oil pump, LS6-2 timing chain, 30lb SVO injectors, SLP 85mm MAF, SLP Lid, K&N drop in, welded in sub frame connectors, Hooker longtubes, custom true duals with Magna pack mufflers, PTC 4400 Stall converter, built 4L60E, Strange 12bolt with 4.11 gears, Billet Specialties light weight rims 15X10 in the rear and 15X3.5 in the front, 28" tall Hoosiers in the rear, ported fast 90mm, NW TB, Custom Racetronix / Walbro 255 pump and dyno tuned by Allan Futral.
What rearend are you running? As far as Patrick G, his knowledge amazes me. He spec'd out a cam for me a while ago when I was still kinda learning...I had no idea there was that much to it. I learned how every little difference in grind came in to play. He made me realize that it is indeed a science. Anyway, sorry Darren, I know we're hijacking your thread here
I flycut my pistons after I milled my heads down. Didn't HAVE to but I did not want to push it close, didn't really want a new bottom end quite yet
