f13 or f14
is there one called just 3600 by itself without hte ss in front of it?
I would also note that the converter will flash higher with more power. So, if you are doing a head and cam and a 3600 stall it should flash close to 3800 or a bit higher.
Keep up the good advice.
5.3 - significantly higher compression, good for low to mid-range torque
LS6 - better for bigger cubes and higher end power
If I'm correct, the ports on their 5.3 heads are smaller then the LS6 ports, which would account for the better torque.
my $.02
Go with LS6, it is a better head. Mill them if you want more SCR. A small chamber is only good down to a point.
LS6>5.3
JMO
