ATTN: Cam Guru's
To run stock rockers with the 1.55" diameter springs, you must clearance the underside of the rockers or you will experience valve control issues above 5000 rpm. Trust me, it happens. It's probably not the cam.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
K, u reading this? Get the car to me 1st thing AM and I will check it b4 we strap it to the dyno........if there is contact, there will be witness marks
No offense intended, (unless you are an engineer, which I doubt, and then offense is intended) but that is a VERY bad idea. Really bad. That is one of the highest areas of tensile stress in the very well designed rocker. It's not like extruded aluminum rockers where there is lots of material which does nothing much but add mass. The stock rocker has almost no material which isn't workling. Grinding material away in a highly stressed area just ain't the way to go, Boss.
You are some sort of cam guru to many folks here, as evidenced by JUNK's response. IMO, which is NEVER humble, you just stepped on your...ahh..."tie" with this one, PG. Your interference analysis may be correct, but your fix, if I understood it correctly, is not.
I'm not a cam guy, but I listen to a couple of good ones.
I don't give a poop if KH504 and JUNK do what I initially suggested, but I really don't want them doing something to compromise the strength of their valvetrain parts.
Read this quickly guys.
Jon
Ever wonder why Comp recomends beehives for XFI lobes? Billy G. has an extremely good understanding of I. Newton. Probably better than anyone I've ever met.
Sometimes it's who you pick as a guru that matters. Evidently you and I don't choose the same folks.
Regards,
Jon
Regards,
Jon
