ATTN: Cam Guru's
The problem is the motor flatlines on the dyno at 5000rpm and goes in the toilet by 5800rpm. This cam was supposed to pull to 7k+. The springs were checked and found to be 125#seat and 400+ open. Below are the specs:
comp cams 3016r/3038r HR116+5
230/242 @ .050 .613/.613
116LS
valve events:
int. open@ 4 BTDC close 46ABDC
exh. open@ 62 BBDC close 0 ATDC
Can someone please tell me what it is about this cam? It made 370rwhp @5200 and went away from there making no power or climbing above 5800rpm
New cam should be here today, so it's gonna be fine. He does, however, want to know what it is about this cam. We have a cam card, but no cam doctor sheet. I degreed forward and backward, checking .006 and .050, as well as LS and got the intake opening @.050 dead nutts at 4* BTDC. Last edited by AznMuscle; Feb 13, 2009 at 01:16 PM.
Initially it sounds like a valvetrain control issue with the XFI lobes, but unless you went to aftermarket roller rockers and dual springs with normal weight steel retainers with low seat loads and wimpy pushrods, 5200 sounds WAY low.
Also heads have titanium retainers.
The cam also may be advanced too far, making it peak way low. Ive seen that happen a few times. Did you degree the cam?
I'm not a cam guy, but I listen to a couple of good ones.
