Compression Ratio (Math gurus Help)
Old Feb 12, 2009 | 08:45 PM
stress fracture's Avatar
Default Compression Ratio (Math gurus Help)
Did I calculate my compression right? The engine is a 6.0L LQ4 stock pistons L92 heads with a 65cc-camber volume. I suck at math I should have stayed in school, I came up with 9.87:1 is this correct?
Bore 4.0
Stroke 3.62
Head Chamber volume 65cc
Pistons are dished (relief pocket) I used 8cc for this
Head gasket .040 Cometic
Deck height 9.240
My pistons do stick up .009 above the deck surface @ TDC
I used 1cc for the crevice volume
Old Feb 12, 2009 | 08:54 PM
JUNK's Avatar
I come up w/ 10.3924:1
Old Feb 12, 2009 | 09:00 PM
BriancWS6's Avatar
I got 10.39 as well.
Thanks Junk..... I think I'II take a Math class this summer
Old Feb 12, 2009 | 09:17 PM
utahws6's Avatar
same thing im doin..only i got 62 cc 243 heads
Old Feb 12, 2009 | 10:15 PM
405HP_Z06's Avatar
Calculation:
Assumption: 4.039" bore head gasket
