Re-Using valve springs.
Old Feb 14, 2009 | 09:35 PM
91ZLS6's Avatar
Default Re-Using valve springs.
Hey Everyone.
Im trying to decide whether i can continue using these springs, or whether i should just pop some new ones in.
Im on a SUPER tight budget, but i wont cut a corner if its putting my motor at serious risk.
My cam is .575/.563 111 LSA.
The valve springs have about 6k on them. Ive also got a set of NIB LS6 springs, but thats right on the boarder of their max lift, so im thinkin it may be best to go with some heavier springs.
Do my springs still have life left in them? Would only put on 3-4k before i replace them with some PRC's. Just dont want to drop a valve, as i cant afford to replace my motor.
Sheldon
Old Feb 14, 2009 | 09:40 PM
sidewayz28's Avatar
WHAT KIND of valvesprings are you running now?
Old Feb 14, 2009 | 09:53 PM
91ZLS6's Avatar
Im running comp 918 springs. Not sure how old they are. Their natural coloured, with no markings.
Just found my cam card.
Duration: 230.7 intake, 223.4 exhaust.
Lift: .581 intake, .564 exhaust
LSA: 111.4*
Old Feb 14, 2009 | 10:01 PM
sidewayz28's Avatar
eh in my own experience i will never run a 918 again. I had like 4 break with a .595/.598 lift cam.
Old Feb 14, 2009 | 10:08 PM
Chrome355z's Avatar
LSA: 111.4*
I wouldn't be afraid to run them, beehives seem to last a LONG time. If your worried have them checked.
Sounds like you had the bad batch. Comp used to have PAC mfg their springs, they dumped PAC (american company) for a "South of the Border" supplier IIRC and that's when they had problems. They have since fixed the issues they had during that debacle.
Although, personally I would stick with PAC springs myself if I was going beehives.
Old Feb 14, 2009 | 10:11 PM
sidewayz28's Avatar
yep this was a few years ago.
Old Feb 14, 2009 | 10:26 PM
91ZLS6's Avatar
Thanks for the info! How can i have them checked?
Local machine shop can check them?
Old Feb 14, 2009 | 10:52 PM
sidewayz28's Avatar
im sure they can
Old Feb 15, 2009 | 09:21 AM
NHRAFORMULA00's Avatar
Take them to an engine builder and have them check the spring rate at installed height and then at rated lift 600 to see if they are within specs.I ran those springs on my car with a .581 lift for 2 years and about 15,000 miles and they were in perfect shape.
Old Feb 15, 2009 | 11:19 AM
91ZLS6's Avatar
Thanks!
Exactly what i was lookin to hear. Dont plan on running them too long, only until i can afford some better springs.
Old Feb 15, 2009 | 11:21 AM
01ssreda4's Avatar
PAC 1218s gets my vote....
