lifter ?????
Old Feb 17, 2009 | 10:27 AM
stdjsw311's Avatar
Default lifter ?????
ok so i built another motor for my car. i put 1.8 roller rockers on the motor the cam now is a 240.242.613.613 but......the problem is i checked the clearance and i had .040 and i was like that will be fine, but i didnt think that the lifters had been sitting for quite a while with out being used. so my question is should i worry about how much the lifters will "pump up". i know in my ford lifters they will colapse quite a bit but i am not sure about ls1 lifters.
Old Feb 17, 2009 | 10:50 AM
405HP_Z06's Avatar
When checking PTV clearance, you must use a solid lifter. If you use a stock lifter the plunger will depress negating the reading.
Old Feb 17, 2009 | 12:16 PM
stdjsw311's Avatar
yeah i realized that a few mins ago. i think i will just put the 1.7s back on there and sell the hs 1.8s
Old Feb 17, 2009 | 12:31 PM
ZMONSTER!'s Avatar
Is there a way to make a stock lifter solid? Im swapping to cranes soon and need to check PTV, but I dont want to have to buy a one off solid lifter!
Old Feb 17, 2009 | 12:37 PM
ss.slp.ls1's Avatar
Yes, you can take an old lifter you are no longer going to use, remove the spring and pull out the bucket. Then fill the lifter with washers and put the bucket and spring back it. You now have a solid test lifter.
Old Feb 17, 2009 | 01:05 PM
stdjsw311's Avatar
i should have done that before the car was in the car but i screwed up and didnt think about that. grrr
Old Feb 17, 2009 | 04:23 PM
ZMONSTER!'s Avatar
What size washer?
Old Feb 17, 2009 | 04:37 PM
405HP_Z06's Avatar
What size washer?
I take apart the old lifter and throw away the internal spring. Insert the plunger into the lifter body; then, use 1/4" AN washers to space the push rod plunger up to the height of the C-Clip. Now you have a solid lifter.
Old Feb 17, 2009 | 05:30 PM
ZMONSTER!'s Avatar
Thanks man thats what I needed, break it down barney-style for me!
