engine assembly lube ok?
Old Feb 17, 2009 | 08:16 PM
nastychevelle's Avatar
Default engine assembly lube ok?
to put on a roller cam instead of oil?
Old Feb 17, 2009 | 08:18 PM
Camaro Jearmy's Avatar
it will work, cam lube is best, anything really sticky that wont just run off it. roller cams don't require break in periods like a flat tappet.
Old Feb 17, 2009 | 08:19 PM
alright thanks
Old Feb 17, 2009 | 11:16 PM
f-bodyguy's Avatar
thats what im going to use
Old Feb 18, 2009 | 09:16 AM
should i put it on the lobes or just the mains?
Old Feb 18, 2009 | 09:18 AM
99blancoSS's Avatar
Guys use oil to avoid buying the lube, use the lube...LOL
Old Feb 18, 2009 | 11:14 AM
mr. Jones's Avatar
i used oil but comp recommends lube.
just don't use cam lube for flat tappets-it has an abrasive in it
very bad for a roller cam
Old Feb 18, 2009 | 11:31 AM
put it on both, be very generous with it.
