crankshaft question
Old Oct 12, 2003 | 06:34 PM
L-EATER's Avatar
11 Second Truck Club
Default crankshaft question
Whats the diff between a 5.7 crank and a 5.3? I know the stroke is the same, etc but I see that on some of the online GM parts websites they are different prices so I am assuming they have a different part number? Are they interchangeable? I want to put a 5.7 crank in a 5.3
Old Oct 12, 2003 | 08:58 PM
strokedls1's Avatar
Default Re: crankshaft question
Same thing. They are interchangable between the two engines. 5.3 just have a smaller bore.
Old Oct 13, 2003 | 08:31 AM
fast2001's Avatar
The 5.7 crank and the 5.3 crank will interchange, but you will have to have the 5.7 crank rebalanced because it has has more holes drilled out which makes it lighter than the 5.3 crank.
Old Oct 13, 2003 | 07:23 PM
L-EATER's Avatar
Thanks, I was thinking the balance was different. I already ordered it so I hope it works!
