water pump question
Old Feb 24, 2009 | 03:05 PM
user 648967286742's Avatar
Default water pump question
well everytime i park my car, i notice that it leaves behind a puddle of coolant. so i guess my question is... is the water pump going out or do i simply need to replace the gasket? is any way i can tell just by looking? really need help. getting tired of buying coolant.
OFF TOPIC: also, any idea where i can get a throttle cable?
Old Feb 24, 2009 | 03:19 PM
vsocks1's Avatar
I would replace the pump and gaskets.
Old Feb 24, 2009 | 04:31 PM
well the pump was replaced with the new motor 17,000 miles ago. so thats why im asking this. the pump isnt that old
Old Feb 24, 2009 | 07:14 PM
nemss1's Avatar
try torqueing down the waterpump bolts and new gasket
Old Feb 24, 2009 | 08:11 PM
LS6427's Avatar
If its leaking from the weep hole under the center of the water pump you need a new pump. Where is it leaking? You need to figure that out first.
Throttle cable:
http://cgi.ebay.com/ebaymotors/_Car-...1%7C240%3A1318
Old Feb 24, 2009 | 08:35 PM
01screaminchickin's Avatar
my water pump was leaking out of the weep hole i replaced it with a gm water pump with new gaskets and torqued bolts and not even 8,000 miles it's leaking out of the weep hole again, so it's possible the pump needs replacing, just put a coolant pressure tester on it and determine where your leak is
Old Feb 24, 2009 | 11:19 PM
ok ill check the weep hole and if its leaking from there, im just gonna go out and buy one. if not i try a gasket and see how that works.
LS6427, thanks i looked forever and couldnt manage to find one.
