View Poll Results: What do you think I should do?
Keep using same oil (mobile 1 5w-30)
11
39.29%
Switch to GC 0w-30
12
42.86%
Switch to Royal Purple 5w-30
5
17.86%
Voters: 28. You may not vote on this poll
Thinking about switching to a different oil in the 408
Old 03-01-2009, 09:38 AM
TJ
TJ's Avatar
with a non factory motor, you need to know bearing clearances before you start switching oils, IMO.
ill never put 5w30 in my ls1. i never used it in my factory 6.0. too thin, IMO.
lot of folks use it, but that stuff is pee water after heavy driving.
Old 03-01-2009, 11:05 AM
405HP_Z06's Avatar
Originally Posted by TJ
<snip> ill never put 5w30 in my ls1. i never used it in my factory 6.0. too thin, IMO.
What quantitative data makes you think this and what specific 5w-30 are you referring? Every brand/type 5w-30 oils falls differently in the 30 wt viscosity range depending on the formulation.
The proper balance is as thin as possible, but still adequately protecting the engine.
Old 03-01-2009, 11:17 AM
383lt1impala's Avatar
Anyone ever heard of motul? I bearly did tru a cousin.
Old 03-01-2009, 11:50 AM
thunder0880's Avatar
I am not sure of the clearance of the bearings its a 408 from tsp though
Old 03-01-2009, 11:57 AM
TJ
TJ's Avatar
mobil 1 5w30.
after a weekend of 17 track passes bracket racing, that stuff is like water pouring out.
never done a test, just going by the eye meter.
Old 03-01-2009, 01:35 PM
INMY01TA's Avatar
Of the three you posted German Castrol is definaetely the best choice. RP and M1 both sheer quite a bit. I've heard great things about the new Castrol Edge as well.
Old 03-01-2009, 02:25 PM
SweetS10V8's Avatar
This is where the internet and people with lots of free time start to over analyze. Your most likely not going to see a change in anything switching to any oil over another, thats the same weight. Now a good filter migh be worth talking about until someone buys them and tears them apart to see whats really inside.
Seriously, just run whatever makes you feel warm and fuzzy. If I filled up your favorite bottles of oil with Walmart synthetic, you would never know!
Old 03-01-2009, 05:22 PM
vettenuts's Avatar
Of the oils listed, GC 0W-30 is the highest viscosity. Better check the 100 degrees C values, you will see this. Putting in a 10W-30 doesn't mean diddly. German Castrol is 11.7 CsT and is close to a 40W, where as the others are around 10 Cst, closer to a 20W at temperature. This includes Mobil-1.
Old 03-01-2009, 05:46 PM
405HP_Z06's Avatar
I agree, but my Dyson UOA WOULD know. I'll stick to what I can see and a UOA with qualified analysis is the only way.
Old 03-01-2009, 05:52 PM
TJ
TJ's Avatar
i run redline 10w40 and it comes out looking like it did when it went in.
friend of mine that runs 2 bracket classes each week and sometimes 2 tracks per weekend, runs 20w50.
any of you serious autocorss or road race guys run light oil?
Old 03-01-2009, 06:07 PM
405HP_Z06's Avatar
I run 3-4 HPDE's (8 open track days) a year with Pennzoil Platinum 10w-30. Max oil temps in the 280 - 285 range for 30 minutes at a time. According to my Dyson UOA's, the oil has had no problems protecting the engine.
I've used Redline 10w-40 under these same conditions and wear was worse than PP 10w-30. It was close between Redline 10w-30 and PP 10w-30, but PP performed better. Redline 10w-40 is too thick for all but the loosest clearance LSx engine. I'm not using an oil cooler, no need, and I use Amsoil EaO32 oil filters.
Old 03-01-2009, 06:20 PM
  #32
TJ
TJ's Avatar
i ran redline 10w40 in my 6.0. 7000 rpm on a regular basis and with a gear and th350, it turn 3800-4000 on the highway. motor had 17,xxx miles and hundreds of track passes. motor, nitrous, i put it to it.
buddy of mine bought it from me and ran it. he ended up melting a piston, and popping the top off another and both the main and rod bearings look like new.
when you say the redline and PP 30wt were close, how do you decipher the test in laymans terms?
thanks.
Old 03-01-2009, 08:46 PM
  #33
405HP_Z06's Avatar
<snip> when you say the redline and PP 30wt were close, how do you decipher the test in laymans terms?
thanks.
The statement was based on oil stability and indicated wear metals in PPM.
Old 03-01-2009, 09:20 PM
  #34
TJ
TJ's Avatar
i know those tests are done, and are accurate. but what is a real life milage difference if you ran 2 exact engines the same way with two different oils?
the advertising companies do is all hype to me. no truth.
the castrol syntec with the dodges on the dyno come to mine. even the shell commericals are comical to me. no truth in that.
Old 03-01-2009, 09:37 PM
  #35
405HP_Z06's Avatar
I have no idea. I have one car with one engine and I'm only one driver so I have no way to tell. If you really want to spend the money to compare two different oils in that fashion, feel free.
I'm only interested in the best combination of products that keeps wear in check. To get there, I've used one of the best tribologists in the industry to perform used oil analysis and develop a regimen to keep the engine in good condition as long as possible. Doing this, I have used many different combinations of oil/filters to arrive at what works.
The statements I've made are based on my last 6 years of used oil analysis with Terry Dyson. I don't know why I even try to help anyone, they would rather believe marketing hype and opinions with no quantitative data or quantifiable proof to support them.
The way an oil drains during an oil change, it's color, etcetera does not offer any insight into the protection it provides.
Old 03-01-2009, 10:29 PM
  #36
TJ
TJ's Avatar
when it comes out like water, or like an oil thats fuel soaked, if youve experienced anything with alky, then youll know what im saying.
what is your recommendation? PP and what filter?
not arguing, just taking suggestions.
thanks.
Old 03-01-2009, 11:00 PM
  #37
405HP_Z06's Avatar
what filter?
1. Amsoil EaO
2. K&N Gold
Old 03-02-2009, 08:28 AM
  #38
1. Amsoil EaO
2. K&N Gold
do you think the mobil 1 im using (5w-30) is the wrong choice. Should the bearing clearance matter to what oil I pick out?
Old 03-02-2009, 09:34 AM
  #39
405HP_Z06's Avatar
I can't say without any data. I would recommend using Pennzoil Platinum 10w-30 over Mobil 1.
Old 03-02-2009, 12:11 PM
  #40
Former Vendor
SBROliver's Avatar
I have used Motul in a lot of import applications and it seems to be very popular.
I agree with running 20W50, personally I like to Brad Penn due to the zinc content it seems to give better wear protection.
On a side note, I would refrain from switching between synthetic and non-synthetic oils. I am not 100% sure of the reasoning but a friend of mine that is a retired GM engineer indicated to me that he had seen this cause failures. I understand that it should be broken in on conventional oil, but I think this was more of a high mileage switch that he was seeing the issues with.
Oliver
