TR 224/224/112 ok with nitrous?
A conventional split w/ a wide lsa would be better but a lot of guys run this cam with N20 and have good results. If you go over 125, you should go to a split cam.
im running a 150 shot on my tr224 112 cam, yes i know its not the best cam, but at the time it was a comprimise cam. still went 131 in the 1/4 on it.
probably be stepping up to something different soon, maybe g5 or tsp231/237
how does this cam do when using nitrous?
I wouldn't worry about a "nitrous cam" until you are 200+ shot. The single pattern cam will work fine.
