question about stock 5.3
I'm getting pretty decent numbers out of mine and I don't have ARP bolts internally. Only have ARP head studs and nuts because of the blower. BUT I don't turn it over 6 grand either, no need with the blower. If your going to use Nitrous all kinds of **** can happen and I'd say you at least need rods, pistons & good top ring with every thing being held together with ARP. JMHO
As far as the heads go there fairly similar except the larger bore LS1 heads hav a larger combustion chamber...
Casting Number 706 and 862
Head: 1999+ 4.8L / 5.3 Liter Truck
Material: Aluminimum
Part Number:
12559862
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 1.89 inches
Exhaust Valve Diameter: 1.55 inches
Stock Head Flow Numbers
Chamber 61.15 cc----0.100--0.200--0.300-- 0.400--0.500---0.550---0.600
Intake 200 cc----------63 ---128----179-----210----218----221-----226
Exhaust 70 cc----------54 -- 93 ----121----145-----163----168----174
Casting Numbers 241, 806, 853
Head: 1997+ LS1 5.7 Liter Passenger Car
Part Number:
12559806 (1997-98) Chambers = 69cc
12559853 (1999-00)
12564241 (2000-03)
Combustion Chamber Volume: 66.67cc
Compression Ratio: 10.1:1
Intake Valve Diameter: 2.00 inches
Chamber 66.67 cc------0.100--0.200---0.300---0.400---0.500---0.550--0.600
Intake 200 cc------------67----122-----178-----215-----219-----223---227
Exhaust 70 cc------------52-----97-----133-----156-----170-----76----180
I do know The very early LS1's like 97-98 use a different type of rod bolt and are not as common. As far as I know the rod is still the same though. Around 99 the rod bolt was re-designed and used a little feral as it's called to help locate the bolt's shoulder I have also been told that it's supposed to help Keep the cap from shiffting under high load. Believe what you want about that as I am only repaeting what I heard. They are a cracked rod design and only fit together one way. The caps are also not interchangable between rods as each one fractures differently. They have the number 143 cast into them on the big end... The rod is the Same length and demision. They were used in the 5.3, LS1, 6.0-LQ4 option
The 6.0L LQ9 and LS2 Use a Beefier rod with a Floating pin but they are the same length as the 5.3 and LS1
Stock rod length For all those applications Is 6.098
The 4.8 used a longer Rod with a 121BW cast in to the cap area on the big end . They measure 6.275
As far as the L33 Aluminum 5.3L goes I am told only the piston is different. They use a 4.8L Flat top with the stantard 6.098 5.3L rod for a bump in compression. I know Because some one on here that actually works for GM looked up the part numbers for the Two applications and it shows the Part number is the same for the pistons. If its a Gen 4 engine Then it has a 48X reluctor wheel on the crank VS. the Gen 3engine's 24X reluctor wheel.
All though this is an older artical it does have a picture of all 3 Rods side by side.
http://www.enginebuildermag.com/Arti...all_Block.aspx
In case some one is curious about the pin height of the pistons between the 4.8 and 5.3 and how that would work... We did the math in this post...
http://www.performancetrucks.net/for...7&postcount=25
flow well because they are a (rougher) copy of the LS6 type intake ports.
The 5.7 (LS1/LS6) rods are different to 5.3 and 6.0.
But, quoted from the "How To Build High-Performance Chevy LS1/LS6 V-8's" by Will Handzell.
1) "...The stock car rods are good to 550hp..... the truck rods to 500.
2) Avoid '97-'98 stock rod bolts, but stock rod bolts from '99-on have been known to handle over 450hp without issue.
3) ...Though it's recommended to fit ARP or other better aftermarket rod bolts whatever power you are going to make....."
Up-grading to the LS6 springs for example give better control of the valve-train and will give you a (slight) power increase in itself; and give you better reliability too.
Any cam change is going to need new push-rods and springs as a minimum.
All aftermarket cams have a smaller base circle (even the ZO6 cam) and so need a different length push-rod.
Other then the early bolts in the 97-98 LS1
Can you explain what is different about the rods from say 99 up in an LS1 Vs. 5.3 and the LQ4 6.0???
