Dipstick tube & piston stop..
So far, I've tried tapping it from the bottom, and using BP blaster. All to no avail.
I'm making a piston stop w/ a used plug. NE1 know how long, from the end of the threads, I should make the add -on piece? [LQ4 stock engine]
I've tried to pull it out, drive it out.. All to no avail. It's now soaking w/ some more PB Blaster, in hopes that will work.
Is there an o'ring on it, that may be stuck? I can't even rotate it in the block.
