Piston Ringland Compression height for Nitrous?
Old Mar 9, 2009 | 12:52 AM
vetteboyc5's Avatar
Default Piston Ringland Compression height for Nitrous?
When looking at stroker kits Im curious as to what is a acceptable ring setup for nitrous. Im not having luck with searching on ringland compression height.
The kits Im looking at show
1.115--- 1/16, 3/16 Rings
1.105 ---1.5, 3mm Rings
The application Im looking into is a 408 LQ9 stroker. Is the bigger the number better? Im in need of some education on this.
Old Mar 9, 2009 | 07:34 AM
briannutter's Avatar
1.5mm is .060" 1/16 is .062. Not much difference between those two packages in terms of available land thickness.
Old Mar 9, 2009 | 12:44 PM
red02Hawk's Avatar
okay i'll ask the key factor here, how much nitrous?
Old Mar 9, 2009 | 03:01 PM
Different piston makers exploit the available ring land thickness for a given compression height in different ways. some maximize the top at the expense of the 2nd. You'll have to give them a call to compare.
