Cam help
Old Mar 9, 2009 | 06:24 PM
STK85's Avatar
Default Cam help
I deciding what cam to go with, The car is see only street no track. current mods are bolts on with a 4000ss. Suggestions? Ive been looking at the following
TR230 112
TR230/336 112
MTI X1
What do you guys suggest? What kinda numbers are you putting down thanks.
Old Mar 9, 2009 | 08:30 PM
conan's Avatar
I vote tr230/236 112lsa. If you had a 6 speed you would be in the 400 rwhp range the a4 will probly be alittle lower.
Old Mar 10, 2009 | 08:20 AM
STK85's Avatar
thanks. What do you guys think...TR230/336 112 or the MTI X1? for a stalled auto?
Old Mar 10, 2009 | 04:47 PM
HTX's Avatar
HTX
all of those are good cams. I would go with one of the ThunderRacing cams. the TR230 is going to be mre streetable than the 230236 however will not produce as much top end power. so do you want top end or low end?
with full boltons either one of those cams are worth at least 30-40 rwhp
Old Mar 10, 2009 | 05:07 PM
TXZ28LS1's Avatar
mti x1 and a vig 3200 stall i put down 395rwhp without a pulley on stock heads.
