Chasing a Knock/Tick
Old Mar 12, 2009 | 08:41 AM
NeXuS's Avatar
Default Chasing a Knock/Tick
Ok So i have been chasing this Knock/Tick for a while now... I thought it was a bad/collapsed lifter.. Got a set of stockers from a friend that had 30,000 miles on them.. Soaked and installed..Same noise still there... On Cold Startup there is no noise... Once the Motor starts getting warmed up you can start to hear it..Once you hit about 200 its there.. not at idle only if i put a good load on the motor or rev it up a few times.. Its louder after you give it gas and while the RPM's are falling you gas it agian.. Not really present above 3500 rpms only under light to moderate throttle or while cruising at a sustained speed.. Then once it starts to knock you can go back to idle and it will knock for a min or 2 then quite down and disappear until you bring the rpms back up... I checked the Rockers (looked good) Pushrods (looked straight) and the the lifters were changed... I have 45-50 psi on cold start up 30ish on hot idle...PSI does raise with RPM increase... I have heard about the O-ring .. But is there anyway a Stock one could just up and Cut or Tear itself... Im stumped here..i dont see how it could be a bearing as it is not there all the time only under certain circumstances... Oh and there is No loss of power or drivablity...I have put well over 5-600 miles on it like this.. I figure and Bearing would have thrown or got louder by now....
-Chris
Old Mar 12, 2009 | 08:53 AM
badaSS346's Avatar
Ok its not my camaro but i am having the same issue with my impreza. I think its a rod knock but it goes and comes....i figure if it was bottom end it would be there all the time.
Old Mar 12, 2009 | 08:59 AM
NastyC6's Avatar
Sounds like a wrist pin
Old Mar 12, 2009 | 09:06 AM
NeXuS's Avatar
Yea..Ive heard a motor with a bad rod bearing it was loud as hell and only got louder with RPM increase and was there all the time... And a wrist pin... I almost was thinking that ... but i had a truck that had a bad wrist pin once and it got really loud in the upper RPMS or the more load you put on the motor ..Mine dissapears the more gas you give it...
Old Mar 12, 2009 | 09:12 AM
1969mach1's Avatar
Are you running stock rockers or adjustables?
Old Mar 12, 2009 | 09:17 AM
NeXuS's Avatar
Stock... All internals are stock
Old Mar 12, 2009 | 09:30 AM
1969mach1's Avatar
i had a bad stock rocker making noise after it would get hot. i sent them to harland sharp and had them rebuilt, no more noise.
Old Mar 12, 2009 | 09:35 AM
NeXuS's Avatar
yea i changed them out with a different set of stockers.. and it has the Same exact noise.... It fits the Rocker Noise problem to a T all the symptoms... But they were changed.. Also sounds like the Oil pump O-ring Deal but its stock and never been Taken apart down there... I think im just gonna ghost ride this B into a Tree and Get some insurance money..lol J/K
Old Mar 13, 2009 | 07:58 AM
NeXuS's Avatar
What about Timing Chain?!? Someone suggested that. Like maybe it has slack and its slapping something.... But i didnt think it was possible.. But i guess with the LS1 Anything is Possible!... I really hope its not a Bearing.
