What do you think of N/A Ford Engine development?
Old Feb 14, 2003 | 05:54 PM
HP-GURU's Avatar
Default What do you think of N/A Ford Engine development?
Of 331-347 cubic inch strokers.
My thoughts are that there are too many of these fully built combo's that fall really short of the type of bar the LS1 has put up.
Built right, these cars could put down similar numbers in similar RPM ranges.
I remember when the bar for LS1 was 400rwhp, then 420, then 440 and now it appears to be in the 450-470rwhp range for hydraulic cammed, street cars that don't need to rev to 7000 rpm to make their power. The rwtq is phenominal too, looks like the really good combos are in the 400-430rwtq range. This is a true testiment to the EFFICIENCY of these combos.
Most of these ford 331-347's are putting down around 350-370rwhp and 350-370rwtq. This is a far cry from the current LS1 development.
On that side they are saying you guys spend ALOT of money to get the type of power.
My thoughts are is it costs in the $4000-$7000 range.
Heck some of the shops such as LG or MTI should put out ford packages for the ford guys so they can get a taste of real N/A power.
Old Feb 15, 2003 | 04:19 PM
HP-GURU's Avatar
Default Re: What do you think of N/A Ford Engine development?
No comments?
Old Feb 15, 2003 | 04:53 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Only NA Ford stuff I follow is the big cube Windsor stuff.
Old Feb 15, 2003 | 08:57 PM
niphilli's Avatar
It is not uncommon for a 347 to go over 400 RWHP, not so bad for engines that have not had a whole bunch of development work in a decade.
Old Feb 16, 2003 | 10:29 AM
LS1derfull's Avatar
I feel same as Pro Stock John, Windsor is more interesting and better choice for builds. I will say from playing with TFS 5.0 heads that they have come a long way with SBF head flow and this makes great potential for making power. Anything can make good power with nice heads, now you need to fit longer rods in block and reduce main bearing diameters......
Old Feb 16, 2003 | 01:47 PM
Fenris Ulf's Avatar
The LS1 stuff will just continue to get better and better. Ford only seems to have any chance on the street with power adders.
Old Feb 16, 2003 | 02:41 PM
Fly By's Avatar
agreed! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Feb 16, 2003 | 03:28 PM
danimal95's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Fenris Ulf:
<strong> The LS1 stuff will just continue to get better and better. Ford only seems to have any chance on the street with power adders. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Apparently you have'nt meet up with any well thought out and well built 347 combos <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" />
<small>[ February 16, 2003, 03:29 PM: Message edited by: danimal95 ]</small>
Old Feb 16, 2003 | 03:31 PM
danimal95's Avatar
you must have over looked fords release of the mach-1 which is only 281 c.i. n/a and is running stock ls-1 times and mph <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Feb 16, 2003 | 03:44 PM
SScam68's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">you must have over looked fords release of the mach-1 which is only 281 c.i. n/a and is running stock ls-1 times and mph </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That 281 is working harder than a 346 is <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> What I am referring to is power per cube.
Old Feb 16, 2003 | 04:20 PM
Y2K2LS1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by danimal95:
<strong> you must have over looked fords release of the mach-1 which is only 281 c.i. n/a and is running stock ls-1 times and mph <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Give us a 32 valve head and see what happens <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Feb 16, 2003 | 06:16 PM
cantdrv65's Avatar
<strong> you must have over looked fords release of the mach-1 which is only 281 c.i. n/a and is running stock ls-1 times and mph <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">They are making LESS power, and running slower traps....Stock Mach1's are dynoing in the 260 to 270 rwhp range compared to the 310 to 320 rwhp range the stock 2002 Ls1s are laying down. Really no contest. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Feb 16, 2003 | 06:26 PM
danimal95's Avatar
Beacause ford came up with an idea of putting an overhead valve in the mustang when at the same time gm quits production of the f-body all together has to tell you some thing.And gm didint put 32 valves in their cars we can play the what if game all day long.And yes the f-bodys are making more power than the mach,s but you need to do alittle more reserch cause they are running identicle mphs mind you with 70 less cubic inches.
<small>[ February 16, 2003, 06:30 PM: Message edited by: danimal95 ]</small>
Old Feb 16, 2003 | 06:34 PM
DailyAluminumBlock's Avatar
What kind of times?
Old Feb 16, 2003 | 06:36 PM
danimal95's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by sscam68:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">you must have over looked fords release of the mach-1 which is only 281 c.i. n/a and is running stock ls-1 times and mph </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That 281 is working harder than a 346 is <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> What I am referring to is power per cube. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Power per cube is explained by your original post when you stated that the 331/347 made 350-370 hp take into consideration a steele headed small emisions cam 331/347 would put down #'s to a similar modded ls-1 with the better heads.
Old Feb 16, 2003 | 06:40 PM
danimal95's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DailyAluminumBlock:
<strong> What kind of times? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I've seen more than 2 in the 106-109 range factory stock.I'm not trying to get into some ford vs chevy thing here but the original post of a 331/347 not making similar power to a ls-1 is completly ludacris.Just want recognition where it is do.
Old Feb 16, 2003 | 06:44 PM
LS1derfull's Avatar
<strong> Beacause ford came up with an idea of putting an overhead valve in the mustang when at the same time gm quits production of the f-body all together has to tell you some thing.And gm didint put 32 valves in their cars we can play the what if game all day long.And yes the f-bodys are making more power than the mach,s but you need to do alittle more reserch cause they are running identicle mphs mind you with 70 less cubic inches. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Here we go again..... GM has been building 300 hp 4.6 liters since 1993 in its Northstar v-8, years before Ford desined convoluded design "300 hp" motors. GM's dont come apart likes Fords either FACT. Fords engines have been behind in engineering since before you were born, FACT.
GM continues to prove more power and reliability comes with basic designs than crappy ohc no flow designs even with 4 valves im not impressed! Lets see you work on a 4 valve 4.6 Mustang car, believe me they need lots of work wether pursuing more power or putting it back together after trying to keep up with stock fbods! Thats all.
Old Feb 16, 2003 | 06:46 PM
106-109 traps are impressive. However, there are factory freaks out there which include ls1s that have run 111-112 traps stock.
Old Feb 16, 2003 | 06:49 PM
LS1derfull's Avatar
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by sscam68:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">you must have over looked fords release of the mach-1 which is only 281 c.i. n/a and is running stock ls-1 times and mph </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That 281 is working harder than a 346 is <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> What I am referring to is power per cube. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Power per cube is explained by your original post when you stated that the 331/347 made 350-370 hp take into consideration a steele headed small emisions cam 331/347 would put down #'s to a similar modded ls-1 with the better heads. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Wrong, iron headed small cammed 347 will not put out same rwhp as modded LS1. Not even close,you better look around here awhile before you come out with statements like that.
Old Feb 16, 2003 | 06:59 PM
danimal95's Avatar
. [/qb][/QUOTE]Here we go again..... GM has been building 300 hp 4.6 liters since 1993 in its Northstar v-8, years before Ford desined convoluded design "300 hp" motors. GM's dont come apart likes Fords either FACT. Fords engines have been behind in engineering since before you were born, FACT.
GM continues to prove more power and reliability comes with basic designs than crappy ohc no flow designs even with 4 valves im not impressed! Lets see you work on a 4 valve 4.6 Mustang car, believe me they need lots of work wether pursuing more power or putting it back together after trying to keep up with stock fbods! Thats all. [/QB][/QUOTE]
Take your prozac,FACT I've seen more ls-1's with rods hanging out the side of blocks that any ford motor,FACT Where not talking about caddy motors were talking about motors put in mustangs and f-bodys,FACT You dont know when I was born,FACT The 03 cobra motors dont put down reliable power?They've used the same basic desighn in the lightnings for over 5 years RELIABLY,FACT and I have worked on several dohc&ohc mustangs and they are easier than most would think and are way easier than GM,s lt-1 I have also done motor swaps on DOHC cobras,FACT Seriously dude you need to relax,FACT with that being said I've said my piece and I'm out,FACT <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
