5.3 heads???
Old Mar 30, 2009 | 07:18 PM
imkindafkedup's Avatar
Default 5.3 heads???
Whats the benefit from running 5.3 heads on an ls1? I have a mild cam in my ls1, if I had 5.3 heads with large enough springs, there wouldn't be any issues. correct?
Old Mar 30, 2009 | 09:39 PM
sman's Avatar
Chambers are smaller I believe, resulting in higher compression ratio.
Old Mar 30, 2009 | 09:52 PM
ksk1980's Avatar
higher compression ratio but they wont flow that great w/ the stock valve size . so what you'd pick up from the higher compression you'd lose due to crappy flow unless you did some porting and had bigger valves cut in. but yeah they'd work
Old Mar 31, 2009 | 03:57 AM
1bdtrk's Avatar
From: Currently, Zormat, Afghanistan....Home staion, FT. Richardson, Alaska
I currently have stock 5.3 heads on my camaro with z06 springs. Read my sig.
Old Mar 31, 2009 | 09:13 AM
iguana's Avatar
higher compression if you swap the 5.3 for the ls1 head you wont see much of a power gane unless you fully ported with bigger valves.
Old Mar 31, 2009 | 09:59 AM
1bdtrk's Avatar
I noticed an increase in low-mid range power and lost very little up top if any. The only reason I did this swap was cause I couldnt afford to buy any ls1 or ls6 heads at the time, only 6.0 or 5.3 and sometimes in alaska you have to take what is available. But I had floated the valves going down the quarter in my stock setup when I accidently shifted to 2nd on my 3-4 and messed up a head and some valves and my pistons and my pushrods. It wouldnt have been a rush deal but I wanted to make it out to the strip one last time before it closed for the year so i got some beehives and pushrods and threw on a set of 5.3's. I really have no complaints. I made the numbers i was looking for at the end of the year with little money invested.
