Installing Caddy racing lifters, what is their preload??
Im doing a cam install and am installing the following components;
Custom Grind Cam(spec'd by PatrickG)
7.425" TSP pushrods(recommended by PatrickG)
CTSV-R Lifters
Stock 1.7 rockers
Anyways, what is the recommended lifter preload for the CTSV-R lifters? Is it the typical .080" or less or more?
CTSV-R Lifters
Stock 1.7 rockers
There is some sewing machine noise since my cam has an aggressive ramp and over .600 lift.However I think it's muted some by the iron block, plus my exhaust is quite loud.
You really don't need a dial indicator' because 1 full turn is .040". I torque in 1/4 turn increments. You start a zero lah, which is the point where the push rod won't turn freely in your fingers. then start counting the 1/4 turns till you get to 22lbft of torque. If you go over 1 1/2 turns go to a shorter PR.
