Injectors
Old Apr 2, 2009 | 07:30 PM
SearayC5's Avatar
Default Injectors
I am running an LS6 motor. With ported an polished heads, Torquer V2 cam, underdrive pulley, headers, vararam, etc should i stay with the stock 28.8 lb injectors or go to 30lb SVO's which on an LSX motor runs at 36lbs. Just wondering before I button the car up.
Old Apr 2, 2009 | 07:53 PM
Loud02ss's Avatar
get the 30lb svo's. im only running a tr224 and my tuner told me to get some 30lb injectors and you got more mods and a bigger cam than me. i have the 30lb svo's btw. great injector.
Old Apr 3, 2009 | 03:06 AM
PREDATOR-Z's Avatar
Since you'll need to tune anyways, it is a good time to run the 30s. Or $$ allowing, get 42s, that way it will give you more room to grow.
Old Apr 4, 2009 | 01:16 PM
SearayC5's Avatar
I am doing the H/C job myself. Well the 243s are being ported and polished by someonse else, but I am doing the install. I will be driving an hour to get to the tuner with the car. Will the car run the 36lb injectors or will I have to drive there nice-e-nice with the stock injectors and switch them once I get to the tuners?
Old Apr 4, 2009 | 01:21 PM
SearayC5's Avatar
The tuner stated that I could drive their with the stock, but never mentioned the 36lbers.
Old Apr 4, 2009 | 08:02 PM
un17real's Avatar
i would tow it there or trailer it up imo
Old Apr 5, 2009 | 07:02 AM
PREDATOR-Z's Avatar
Do not drive untuned injectors. Serious motor damage can result. You can swap them in the parking lot before tuning.
Old Apr 5, 2009 | 08:34 AM
vsocks1's Avatar
Yeah I would drive with the 28# injectors and have the tuner change them to SVO 30# and tune!
Old Apr 5, 2009 | 09:26 AM
davered00ss's Avatar
Moderator
I changed mine in the parking lot where my car was tunned. It takes 10 min and a 10 mm socket & wrench.
Mods in Sig, I'm 432rwhp & 403rwtq running SVO 30# injectors. Not sure what my duty cycle is on them, but checked out by Slowhawk when he tunned it. He told me what it was, but I forgot. I know it was good.
Old Apr 5, 2009 | 07:03 PM
SearayC5's Avatar
Alright thanks guys. So can I drive it to the parking lot. Change the injectors. Then idle it on to the dyno, etc?
Old Apr 5, 2009 | 09:05 PM
'02 WS6's Avatar
FICInjectors recommended not to use SVO 30# due to the spray pattern, and instead get a set of Bosch III 36lb. Just passing on the same advice they gave me.
Old Apr 5, 2009 | 10:55 PM
SOMbitch's Avatar
Good to see you back on here Pred..... was kinda wondering where ya been and if everything was ok in your world Glad things are cool with ya
