h/c checklist
Old Apr 5, 2009 | 01:11 AM
firechicken76's Avatar
Default h/c checklist
heads #799
cam mti x1
Hardend Pushrods
ls2 timing chain
comp 918 valve springs
gasket kit
tune
can you guys think of anything else ill need? I was thinking about doing some ls7 lifters too, car has about 40k on an 02 ls1
Old Apr 5, 2009 | 01:23 AM
massconfusion's Avatar
definately headbolts unless u have studs and do the lifters. i have the ls7 lifters, they are nice cheap insurance and you don't need the chain but that is good insurance too. yet to hear of a borken chain sure one is out there though
Old Apr 5, 2009 | 01:24 AM
Originally Posted by massconfusion
definately headbolts unless u have studs and do the lifters. ihave the ls7 are nice cheap insurance and you don't need the chain but that is good insurance too. yet to hear of a borken chain sure one is out there though
im on a limited budget, so would the lifters be better to get than the timing chain? how about oil pump?
Old Apr 5, 2009 | 01:28 AM
LCplmarine98's Avatar
I am going with the TR ported LS6 oil pump but mines a 98, you would prolly be alright.
Old Apr 5, 2009 | 01:31 AM
lifters are much better and your oil pump is probally good but i think their cheap and its easy to do with heads with the heads off. once again cheap insurance but personally i would say your good. i've never heard of an oil pump going bad at 40k unless we're talkin dodges
Old Apr 5, 2009 | 01:32 AM
i think ill order my pushrods and springs tomorow, anyone know how much a gasket kit costs?
most expensive thing will be the tune......grrrr
all i have now is the cam, and the heads will be here wed, i was thinking about having some porting done to them, only to pick up around 30cfm or so...
Old Apr 5, 2009 | 01:36 AM
THunder has em for about 85 and its everything you need. Do the heads have to come off to change the lifters?
Old Apr 5, 2009 | 02:18 AM
im doing a head and cam swap, so the heads will be coming off. not sure, ive never been inside an ls1
Old Apr 5, 2009 | 08:49 AM
vsocks1's Avatar
Heads have tgo come off to change lifters!
If you change lifters get some new LS2 lifter trays for $30.
Old Apr 6, 2009 | 12:29 AM
Thanks i was wanting to know about that i wasnt planning on taking the heads off so i will have to see, dont have the cash for new heads wonder if stockers are worth gettin ported if so maybe then i will pull em.
Old Apr 6, 2009 | 12:32 AM
i honestly dont see why they wouldnt, alot of ppl on here have made good power on 241 heads, if your on a budget like me and cant afford an aftermarket setup, get your stockers shaved and ported....i found my ls2 heads for 425 shipped, so i couldnt pass them up.
Old Apr 6, 2009 | 12:34 AM
It seems like all the projects i do start out small then i just keep findin more and more out and it just keeps getting bigger Thanks for the info.
Old Apr 6, 2009 | 01:14 PM
archiejay's Avatar
you need to add BEER to the list
Old Apr 6, 2009 | 01:24 PM
most important part.
