Cam specs of Cartek "X" pkg, or JPR pkg?
That is freakin amazin that cartek's cam is so conservative for the freakin dyno and track times they pull. Perfect example of proper selection of all components working together in perfect harmony making maximum power!
Cartek X-Package
I am running their latest X-Package the cam is a 224/228 580/580 113 lsa. They don't belive in using a huge cam to make power .. my car made 467 hp and 417 tq to the wheels with a Moser 9" 35 spline (gun drilled) axles with 4.10 gears.
I am very happy with the power and numbers the car is running.
Shorty Director
Once people realize it is not just a single part that produces good #'s they would stop trying to find out cam specs.. The horsepower is in the heads.. After you get a good set of heads you just mess around with your own cam specs that you design to see what works with your combo. Every car is different.
Senior Member
That couldnt be more wrong.....
You just dont buy a "good" set of heads and then buy 5 different cams untill one "works" with what you have. You have to match them together. Carteks cams are ment for their heads, thats why they sell it as a package and it makes the good numbers. Look at the old school stuff like the Holley and Edelbrock stuff... Sold as a PACKAGE. You dont just buy one part and buy another part and more of the same parts untill it works.
Shorty Director
Carl what do you think Cartek and JPR did..? Pull a rabbit out of their hats? R and D man.. The poster obviously want to know the cam specs for a reason. He does not have Cartek or JPR heads? Do you think purchasing their package is going to automatically get you 450rwhp? I know you thought that with your package, but REALITY hit you quick.. It does not matter what their cam specs are.. If you do not want the package because they wont tell you the cam specs then purchase from someone else.. Hell it took you quite a while to reveal who did your H/C package.. Why is that? When it suits you its ok? You as a moderator should not post in these type of threads, but just like you do on our local forum, you do here. You do nothing but start shiznit.. You give LG and Absolute a bad name..
Senior Member
Where did this come from???
You as a moderator should not post in these type of threads, but just like you do on our local forum, you do here. You do nothing but start shiznit.. You give LG and Absolute a bad name...
Shorty Director
Carl I am not going to go back and forth with you. I was telling people they could spend the time to research their own cam profile instead of trying to steal someone elses specs. If they cant get the specs from the vendor they should not purchase if they do not like not knowing.. Plain and simple. You took my quote and obviously have a problem with what I said. I have researched cams.. I have took the time to put several cams in my car.. Some people are not looking for MAX horsepower and want something a little milder.. Thats why I made my comment.. The vendors have put in many hours to develop a cam that works well with their heads to give you the MOST horsepower peak as possible.. Peak #'s sell H/C packages.. Not everyone looks for peak #'s.. Many local people I talk too want something that has a lot of lowend tq and does not require a 4.10 gear or higher to toodle around town in.. Not everyone has the luxury of having a backup vehicle to build a high horsepower car w/out fear of breaking down. My car could sit from now until I feel like fixing it. I have 3 other vehicles at my disposal. So sometimes purchasing a package deal is not what everyone wants.. Its funny you say you did not want to tell people what you have, but you do not like others keeping secrets.. You mentioned a select few knew. I am sure Cartek and JPR told a select few what the cam specs are.. You did not like the fact my buddy Mike did not share the JPR cam specs, but Mike is very happy with his car nonetheless.. I do not see any Cartek guys dyno'ing high complaining about not knowing their cam specs..
Shorty Director
Originally Posted by SPANKY LS1
I am just curious. I just wanted to see approx. what size cam they were running. Obviously, JPRs 450+ dyno results are a lot more impressive if they were done on a 224/224 that Joe swears by, then if it was done with a "G5X2 size cam" . Same to be said for Cartek, more impressive that its only a 224/228, if thats truly the case.
Nobody said that they should say, or that anyone wanted any package. It does matter what the specs are, for example, if JPR is reaching 450+ rwhp, its more impressive if he is using the 224/224 that he has always sworn by, than if he is using a cam that is similar to other 450+ hp cars are using. Thats all.
Is that how you ended up with 396 rwhp?
This thread was started to start shiznit and nothing else.. You already have a package so why should you care? If you are not impressed by their setups then dont be. This thread and thread similar to this should be locked b4 they get heated.. This is not going to help anyone and I see no technical relevance..
Shorty Director
Anyone wanna spill the beans on what size cam the JPR and Cartek "X" packages are using?
Thanks, Shawn
Thanks, Shawn
If you would have went more in depth on your opening post I think you would have came across a little better.. I would think Cam size and Porting style would be a good topic. Matching runners with the cam is more important than people think.. It would be good to know what the runner size of most vendors heads are and compare them to what cams they use..
I agree that a set of heads as to be matched to a cam (see sig ), and I would like to see a head comparison at a neutral location. Maybe every head porter (TEA, AS, JPR, MTI, Cartek, ARE, PP, GTP, RGR, etc) can send a head to a shop that would then measure runner size, flow a random port (I really doubt that in some cases, the port that is to be flowed doesn't get some "special attention" ), but it will probably never happen.
Some people around here are so touchy. I really don't see how this thread could be used to start sh*t. He just asked a simple question to see what size cam vendors are using to get the 450+ numbers. Truth is, he prolly won't get an answer. The only one that I know is avalible is the Cartek 224/228. All the others have been kept secret. Why, I don't know. If a cam only works with vendor "A's" particular heads, why would it be so important to somone else? You don't see 50 people rolling with the Cartek 224/228 cam now do you? The only thing I can see wrong with this post is that Spanky has a top secret cam of his own, that he knows the specs to, but won't reveal. Not that I care either way, just making a point.
Shorty Director
I love watching Country Boy and Vince go round and round. I wonder what started that? I can say from talking to JPR myself that he is honestly scared of other people taking his specs copying them, selling it cheaper, and making him less money. I believe he really does want to share the specs with others for the technical aspect of it and because he is proud of his work,, The truth however is that the business side of anything is corrupt and people lie, steal, and walk on/over others to make money. IMO you can't blame anybody for wanting to protect their own hard work. This is the real reason for the "secret specs".
Back on topic though,,, One thing I can say about my cam even though It's not the exact specs is that it does not buck in the 1300-1500 rpm range and the idle is better than my TR 224 cam but I do have tuning now so the idle may be a mute point. I also have above 350 tq at 3200/3300 which is pretty good and my peak hp hits around 6100/6200 rpm so maybe some of you can draw some basic conclusions from this as to the cam specs.
