317's or 806's??
Old Apr 8, 2009 | 01:26 PM
BlackTA96's Avatar
Default 317's or 806's??
Well, my 6.0 lq9 will be here on monday. And I about to make an order with TSP for a ms3 and some other goodies.
I have a blown 98 ls1 with 806's. The lq9 is coming with 317's.
Should I use the 317's or the 806's on the new motor?
I know 317's flow better, but compression would be lower.
So I'm kinda on the fence about which ones to use.
This is just a temporary solution till i get some cash saved up for some ported 5.3's or something.
So help me out guys....
Old Apr 8, 2009 | 04:27 PM
BlackTA96's Avatar
crickets....
Old Apr 8, 2009 | 04:47 PM
sroach20's Avatar
why not mill the 317s since they flow a hell of allot better than the 806s.
Old Apr 9, 2009 | 07:13 AM
BlackTA96's Avatar
If I mill them, I'm afraid they will have ptv clearance issues...
Old Apr 9, 2009 | 07:45 AM
sroach20's Avatar
put the ms3 in and check ptv, it will let you know how much you can take off the heads. even if you left them stock i would stick the 317 heads on because they flow allot better. you will still have good compression because the lq9 has flat top pistons.
Old Apr 9, 2009 | 07:46 AM
BlackTA96's Avatar
alright...i'll do that.
Thanks.
Old Apr 9, 2009 | 07:52 AM
sroach20's Avatar
just hold off on buying pushrods till you decide what your doing and measure.
