Took my valve covers off, need help!
Old Apr 10, 2009 | 12:53 PM
Vicinity's Avatar
Default Took my valve covers off, need help!
I unbolted everything to the point where I can pull my valve covers and I've been using LS1howto to get there.
I cannot get my valve cover out of my bay because I have a line the looks to be covered in duct tape and said "CAUTION FLAMMABLE!" on it. Can I remove this and if so, how?
Old Apr 10, 2009 | 12:56 PM
Speed Density's Avatar
hashtagBMW
That line is most likely a fuel line. Do you have pictures of the situation?
Old Apr 10, 2009 | 12:57 PM
Vicinity's Avatar
Let me go snap a few.
Old Apr 10, 2009 | 01:01 PM
Vicinity's Avatar
The duct taped line and the metal line next to it that seems to recess into the dash (I think thats AIR or EGR, Idk, 2001 car)
Old Apr 10, 2009 | 01:09 PM
hashtagBMW
Yep, thats the feed fuel line. Just get a 3/8ths GM quick release and pop the line off the rail and take the cover off. Its not going to hurt anything.
Old Apr 10, 2009 | 01:12 PM
Vicinity's Avatar
Alright, thanks. I was afraid if I took it off it'd squirt fuel everywhere, lol.
Old Apr 10, 2009 | 01:13 PM
MeentSS02's Avatar
Kleeborp the Moderator™
That's not duct tape, but as indicated, the lines are for the fuel feed and EVAP system.
Old Apr 10, 2009 | 01:22 PM
Vicinity's Avatar
Ok, I need help getting it off, I can't figure it out. Theres no place for a wrench, and the other line (that goes into the electrical thing next to the green **** in the second pic) won't come out.
Old Apr 10, 2009 | 01:31 PM
dlove's Avatar
just wiggle the valve cover out. you don't have to take the fuel line off....
Old Apr 10, 2009 | 01:35 PM
Greekey's Avatar
No need to disconnect fuel line to remove the cover. Just wiggle it out like stated above.
Old Apr 10, 2009 | 01:41 PM
max_ta's Avatar
as stated above you are going to need a release tool to do that, you can either use a a/c line tool 3/8" or a Gm gas line tool
Old Apr 10, 2009 | 01:44 PM
Vicinity's Avatar
Ok, I managed to get it out without disconnecting the fuel feed.
Any tips for removing rockers?
Old Apr 10, 2009 | 02:47 PM
ArchetypeZ28's Avatar
Former Vendor - No longer Vendor
What are you trying to accomplish?
Old Apr 10, 2009 | 02:59 PM
98transamtx's Avatar
no need to disconnect the fuel line, you sill spill fuel everywhere, get ready to get messy!
Old Apr 10, 2009 | 03:12 PM
Vicinity's Avatar
Checking for a bent pushrod.
I'm done, I didn't find anything.
My car makes a diesel sound and its coming from the driver side, one of the first 2 cylinders. I've been told it might be a lifter, now I'm thinking that too.
I'll have a new sound clip later.
Old Apr 10, 2009 | 03:13 PM
bigboykilroy's Avatar
are they the stock rods still, if they are REPLACE THEM
Old Apr 10, 2009 | 03:16 PM
jsteele90's Avatar
that damn fuel line is a PITA to disconnect on mine i hate it
Old Apr 10, 2009 | 03:23 PM
Vicinity's Avatar
I believe they are. They looks bronze, round edges with a divit, I don't really know what to look for on a stock rod to identify it as stock.
Old Apr 10, 2009 | 03:40 PM
Sounds like the stockers...Replace them. get a good set of Trick flow 7.4 Chrome molly. you will not have to worry anymore, and you will know for sure.
Old Apr 10, 2009 | 07:40 PM
futuref-body's Avatar
pull the bolts out of the cover (not necessary but makes it a little easier) and slide the cover between the two "duct taped" lines and the power steering.
