Still looking for Hp after cam install.
Im at the point where im gonna pull the timing cover back off and make sure the dots are lined up on the sprockets. Im positive they are, the car wouldnt run this good if they werent right??? I have an atap file if anyone would like to see it.
No misfires runs smooth?
if u need to be at TDC..then i did my cam wrong..and im one luck sob that im racing all day and havent had a prob
(looking at it again..do u mean..when the piston #1 is tdc then the crank and cam should be lined up at this position?)
FWIW, to do the cam, the engine doesn't need to be TDC on #1 as long as you mark the cam gear before you take it off the cam dowel and reinstall it in the exact same position as it was when you took it off and the crank doesn't move. Lining up the dots just gives more reference, that's all.
