LS1 Rebuild
Old Apr 12, 2009 | 02:24 PM
christrusler's Avatar
Default LS1 Rebuild
MY motor is shot... How much do you think a shop would charge to do a stock rebuild ?
Old Apr 12, 2009 | 05:11 PM
02b4ccamaro's Avatar
i going with a lot, whats wrong w/the motor? burnt valves? holes in the pistons? bent rods?
Old Apr 12, 2009 | 05:30 PM
I've checked the lifters, pushrods, valves, they're all fine. I can hear metal, and a knocking noise.
Someone give me a ballpark figure for doing a stock rebuild at a shop
Old Apr 13, 2009 | 12:00 AM
Notmyvette's Avatar
Depends how bad it is and how deep of a rebuild you want to do or it needs...it could be a simple as rebearing, rering, hone the cylinders and throw in a oil pump, timing set and gaskets...or you could have to get the crank cut, rods reconditioned, bored or resleeved or more On Top of the first option. Depends on the damage....and how much the shop charges...
Old Apr 13, 2009 | 07:17 AM
i understand there's alot of variables involved in this... so like 2k or 3k?
Old Apr 13, 2009 | 02:49 PM
turbols1sex's Avatar
mine is making the same noise i pull the oil pan and nuthing it all looks new if u find out what it is pm back pls
Old Apr 13, 2009 | 03:23 PM
JDishong's Avatar
Around here its 3000-4000 to get a decent rebuild. Parts and labor
Old Apr 13, 2009 | 03:34 PM
NemeSS's Avatar
for around 3k u are able to get a stock rebuilt 6.0 engine.
find a 6.0 longblock, have it bored .030 with stock replacement pistons around 400$ with rings, pressed to stock rods, rebuild the 317 heads with upgraded springs and rev 2.02 valves and valvejob, milled. ls6 cam. with new gm valvetrain, ls2 chain, lifters,. can reuse stock rocker arms..
