Um What did i do???
Old Apr 20, 2009 | 12:50 PM
nalmak's Avatar
Originally Posted by got-a-ls1
i honestly think the noise you heard was the engine back firing because you didnt have the plug wires installed on one side of the motor. if you look at the firing order it alternates from side to side... if one side doesnt fire the motor is going to make some funny sounds.
i dont think anything else could make a noise as loud as you described except for maybe a connecting rod or crank breaking.
maybe i did blow it out..but could it be possible on just start up???..
**** almost made me def..no joke..
Old Apr 20, 2009 | 12:52 PM
nalmak's Avatar
yep sounds like a muffled hissing if you turn it slow... very difficult to turn it fast
yep..so i know it aint ptv clearance..the only thing i can think of is the wires..but if that is the case the other rockers should have the same ill affect right?..its not a rod because i can still move the other rocker on that cyilinder if i turn the motor
Old Apr 20, 2009 | 12:54 PM
got-a-ls1's Avatar
defintely could make a loud sound onstart up. helped my brother get his iroc-z started after a rebuild and he turned the distributer 180° out with out telling me and that made a hell of a backfire sounded like a gun shot...
cam looked like this right? its hard to see perfectly in the car so i verified mine with a camera... im pretty sure you have your right, never hurts to double check though. dots can be hard to see.
Old Apr 20, 2009 | 12:57 PM
nalmak's Avatar
yep looked like that..
i tried a different rocker, same result..so its either the lifter (which i doubt), or a valve or a spring..
let me tak a pic
Old Apr 20, 2009 | 02:19 PM
nalmak's Avatar
WELL i am very confused right now..
I went ahead and just tightened the rocker on the spring that is in question and it didnt move!!!!
WTF!!!!..I am very in shock and i don't get it..
Wierd!!
Old Apr 20, 2009 | 03:49 PM
got-a-ls1's Avatar
lol atleast its better... the lifter probably finally firmed up
Old Apr 20, 2009 | 06:22 PM
nalmak's Avatar
Well after checking out the rocker..I proceded to place the rocker on the on the spring and tighten it..But i noticed something..When the rocker is on the rail..It wont compress the spring..When it is OFF the rail it will compress the spring..
So i finally found out the problem
See the shorter pushrod 2nd from the last..I guess that is the problem...Don't know what it means, but i guess the heads have to come off
Old Apr 20, 2009 | 06:36 PM
billyb's Avatar
keep the faith, good luck buddy
 Michael S. Palmer
Old Apr 20, 2009 | 07:12 PM
topher455's Avatar
Stupid question but that pushrod is the same length as the rest right?
Old Apr 20, 2009 | 07:14 PM
nalmak's Avatar
Yes it is
Old Apr 20, 2009 | 07:15 PM
nalmak's Avatar
Im trying
Old Apr 20, 2009 | 08:24 PM
  #32
nalmak's Avatar
Either the lifter collapsed or the cam has a flat spot
Old Apr 20, 2009 | 09:20 PM
  #33
ghettocruiser's Avatar
Was the push rod moving up and down at all while turning the motor over? Just not moving up enough to hit the rocker right?
Sounds like a lifter went haywire. Wonder if the guts blew out of the lifter. Like the retainer came out somehow. Not sure if that can even happen...but maybe the loud noise was the lifter springing apart???
Im keeping an eye on this out of curiousity.
Good luck man! Hope its something simple and easy...and cheap for ya.
J.
Old Apr 20, 2009 | 09:50 PM
  #34
1SLwLS1's Avatar
subscribing, my vote goes to a faulty lifter
Old Apr 20, 2009 | 09:58 PM
  #35
nalmak's Avatar
it was moving up and down when i was turning it by hand..When i went to start it up, thats when i heard the "pop", which was me not connecting the spark plug wires to the spark plug..Ok I can understand that, along with some smoke.
But that "PING", was something wicked..I thought i blew a hole out of the block, and looked everywhere for a chunk of aluminum lol..
i mean they are non-adjustable so torquing them to 22ft pounds is standard..I did the same exact thing for EVERY Rocker..So i am attributing to this as a Lifter too, but ill pull the heads early in the morning and take pics..
If there is a crack in the block.Im selling the car
Old Apr 21, 2009 | 09:29 AM
  #36
oneBADDz's Avatar
You soaked your lifters for 7 days? You killed a lifter no doubt. When you replace them, don't do that.
Old Apr 21, 2009 | 09:45 AM
  #37
nalmak's Avatar
Whats the difference if i soak it for 7 hours or 7 days..It has to be pumped with oil...When its filled up, then thats it...It wont soak up anymore??
  #38
bigboykilroy's Avatar
GM Lifters are not recomended to be Soaked.
Old Apr 21, 2009 | 09:47 AM
  #39
nalmak's Avatar
Really....I have never heard that at all...Not saying you are a fibber, but that is something i never heard of
Old Apr 21, 2009 | 09:48 AM
  #40
Its in the New Chris Hanson LS1 book.
