Um What did i do???
Old Apr 21, 2009 | 09:55 PM
  #61
vsocks1's Avatar
Originally Posted by bigboykilroy
Ill find the page, but it said not to soak them that it has a special coating internally, just to lightly oil up the out side before install......but that so SUCKS what happened regardless.
Soaking may not be necessary....but I can't imagine a special coating being used that is degraded by oil..someone should be able to validate this!
Old Apr 21, 2009 | 10:31 PM
  #62
got-a-ls1's Avatar
told ya it was a lifter that wasnt pumping up! sucks you had to take the head off but glad you got the problem figured out and hopefully fixed by now!!
Old Apr 22, 2009 | 01:00 AM
  #63
nalmak's Avatar
Yeah Thanks everyone for your help.Just finishing cleaning out the coolant from the bolt holes..Get everything torqued down tommorow, then will post back up, and let you know how it runs/'sounds
Old Apr 22, 2009 | 07:00 AM
  #64
topher455's Avatar
Good job hangin in there. Take your time putting it back together and when in doubt always threaten the car with craigslist. Works like a charm...
Old Apr 22, 2009 | 08:24 AM
  #65
oneBADDz's Avatar
Glad to hear you found it!
(don't soak em this time!)
  #66
bigboykilroy's Avatar
Awsome !!
Old Apr 22, 2009 | 08:32 AM
  #67
I did fing the Chapter in the book under Non-Soakable Parts.
It said not to soak the lifters or rockers in mineral spirits or any type of solvant.
That the solvant will pull the good stuff out of them, if you do solvant wash them then you do need to re-oil bath them for several days working the oil back into them.
But new lifters should contain plenty of oil internally to install and fire the engine, just put a light amount of oil on the roller lifter and install.
So unless the Lifter or rocker manufacture says to specifically oil soak them, its unnecessary so says GM and the book.
Old Apr 22, 2009 | 09:12 AM
  #68
bjamick's Avatar
I was just checking this thread and I was going to tell you to shake them lol. Glad you got it figured out. Now replace and drive happy.
Old Apr 22, 2009 | 07:35 PM
  #69
vsocks1's Avatar
Yeah, soaking in mineral spirits or solvent is MUCH different that soaking in oil!!
Old Apr 22, 2009 | 08:01 PM
  #70
driftpin's Avatar
Were those LS7 lifters or aftermarket? New, Used?
Old Apr 22, 2009 | 09:40 PM
  #71
nalmak's Avatar
Those were LS7 Lifters used..I bought em of a car that had 13,xxx miles on it..But i guess you get what you pay for
Old Apr 22, 2009 | 09:46 PM
  #72
nalmak's Avatar
Ok so everything went good, no wierd nosies or anything..But that damn collant crossover pipe keeps dripping even after i put RTV all around it.On the driver rear and passanger front..But thats not my worry right now
I went to start the car, and it dosen't idle at all cant even hold it a 1,000 RPM..But around 2k or 2500 Rpm, it will hold a bit but the minute it drops past that it dies
Any way the car backfires like CRAZY!!...So i pulled the plugs and they were darck black like hell\..So i got some new ones, and the samething happened in cylinder #5 and #7 after 3 good tries, trying to idle it and hold it i pulled it again and came up with this on brand new plugs
Im gussing i have a couple bad fuel injectors dumping too much fuel..Because the others on the driver side dont look like this at all..And it backfires crazy and loud (maybe cuz im in the garage.), But what do you guys think about all this??
Old Apr 22, 2009 | 10:31 PM
  #73
got-a-ls1's Avatar
odd that it is happening to only one side... but if i remember this is a 228/230 cam right? do you have any tune at all for this cam? its not surprizing it wont idle if not
Old Apr 22, 2009 | 10:34 PM
  #74
nalmak's Avatar
no tune..Yeah thats the cam..Well i gotta break it in somehow..Any ideas?..And its weird it only on 2 cylinders..
Old Apr 22, 2009 | 10:49 PM
  #75
05 GSXR 1XXX's Avatar
man talk about bad luck! im prayin for ya that you get this resolved!
This story makes me want to hold off on my swap lol
Old Apr 23, 2009 | 12:29 AM
  #76
nalmak's Avatar
I think your fine.
The previous owner, Nawwzed it untuned!!!..And never changed the gear ratio from stock to 4.10, so the mileage looks higher than it really is..
Thats why i always threaten the car with craigslist..
Lol..Anyway..Im kinda stuck, and dont really understand whats going on..
Old Apr 23, 2009 | 12:50 PM
  #77
nalmak's Avatar
LOL..I figured out the problem
PUT MY COIL PACKS ON BACKWARDS
Im such a dumbass..I just started laughing like crazy..Got it idling and everything sounds pretty sick..No weird noises just a mean *** rumble..
No just gotta fix the dripping for the crossover pipe and im done.
Ill post the vid in a minute
Old Apr 23, 2009 | 01:19 PM
  #78
nalmak's Avatar
Default vid
It wont let me upload..Its in MPEG format
Old Apr 23, 2009 | 07:55 PM
  #79
driftpin's Avatar
Glad to hear you worked it out. I've run in to **** like that before. I'm always reminded of Bily Bob Thorton in Sling Blade when they all couldn't figure out what was wrong with that lawnmower, and he comes along and says "It's out of gas".
Been there, done that.
Old Apr 23, 2009 | 09:10 PM
  #80
67rsss's Avatar
You can get all four of the little gaskets for the steam lines in a package in the help section of your local area parts store. About $9 for the package. Don't use RTV. In fact, there is very little RTV used on these engines. I remember a few dabs on the oil pan, thats it...
