heads on a budget
Old Apr 24, 2009 | 10:11 AM
  #41
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
The only thing with that book is it's now years old. I think there's several new book options pretty soon that have newly updated information featuring the newer LS stuff
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old May 7, 2009 | 10:27 AM
  #42
Y2K WS6's Avatar
Any titles/authors? always interested in more info!
Old May 7, 2009 | 11:03 AM
  #43
Sales2@Texas-speed's Avatar
"How to Build and Modify GM LS-Series Engines" is the one I'm waiting for. Should be a good one , I am told! A few places already have it available for pre-order. I believe we'll be one of the handful of sponsors here that will be offering this one in the near future.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old May 7, 2009 | 11:14 AM
  #44
99Ls1fever's Avatar
I went with the TSP PRC 2.5 heads bud, they costed me right around a 1k bucks they are super clean, love how you guys had presion racing componets on the bottom of the head from front to back. You cant beat the bang for the buck that TSP is offering right out of the box performance with good valvetrain perofrmance too. Good flow number, picked up around 40 rwhp
Old May 7, 2009 | 03:03 PM
  #45
topher455's Avatar
What do you charge to port a customer supplied set of 243's? Also what all is included in the service.
Old May 7, 2009 | 03:08 PM
  #46
Sent you a PM
__________________
Old May 7, 2009 | 07:14 PM
  #47
ramdaspadhye's Avatar
You can either have a valve job and larger valves done on yours, or you can find a set of 243's or even 317's for usually cheaper. You can have the 317's milled .030 and larger valves and a valve job done and they'll flow better than the 243's
Old May 7, 2009 | 07:15 PM
  #48
Sent you a PM
Send me one too. Interested in having my 317's ported!
Old May 7, 2009 | 07:29 PM
  #49
NemeSS's Avatar
a 241 with upgraded 2.02 rev valve and vj will equal the stock flow of a 243/799 and a mill can go up to 10.7:1 scr for long duration cams.
that will prolly make for budget performer.
Old May 7, 2009 | 07:30 PM
  #50
Nice nice. I'd go with that then! Have 'em CNC'ed once you get the cash and you'll make some serious power regardless of the cam!
Old May 7, 2009 | 10:31 PM
  #51
bulldogSS's Avatar
look at Katechs site. picked up a pair of stage II 241s for $500. hell of a deal. couldnt see spending an extra 1000-1500 for 10hp.
Old May 8, 2009 | 07:52 AM
  #52
topher455's Avatar
Im not sure how the 317's will flow better than 243's given that they have the same ports. Also the chamber isnt as efficient on the 317 when compared to the 243. Milling the heads down to near the compression of the 243 will also restrict cam choice. Can you better explain your statement? If you like 317's that much I'll sell you mine for $300 shipped. I just picked up a set of stock 243's yesterday so I dont need them anymore.
Old May 8, 2009 | 01:15 PM
  #53
danf1000's Avatar
There is always lots of doubters of home porting, but I say $100 and 30-40 hrs can get you ground down and profiled valve bosses, polished exhaust runners and combustion chambers, casting edges and rocker bosses smoothed out, ramp taken down, port matching, and short side blending.
That's the best bang for the buck on here.
Old May 8, 2009 | 07:34 PM
  #54
SLP Firehawk's Avatar
yeah thats originally what i was going to do but i think by the winter i'll have enough money saved up i'll put on a set of 5.3 prc heads or trick flows.. we'll see depends on the budget i dont really want my car ripped apart during summer as it was down all last summer due to my rear blown up (3rd time)
Old May 9, 2009 | 08:29 AM
  #55
topher455's Avatar
I ported a set of heads for my old 5.3 motor and that thing def got it. But man it was alot of frickin work. When I fnished and was happy with them I swore I would never do it again.
Old May 21, 2009 | 10:18 AM
  #56
orangejuiced86's Avatar
I am debating on cleaning up my 317's I am doing a 6.0 build right now and I am going to put a good rod and a domed piston in it. My compression will be right around 11.2:1 with the the stock 317 chamber. I will just clean them up alittle myself, no heavy porting.
Ill do this and test, then maybe down the road take the heads and have them cnc'd and have something to compare it to.
