heads on a budget
Old Apr 22, 2009 | 05:46 AM
SLP Firehawk's Avatar
Originally Posted by disc0monkey
or get the 241s ported. honestly if your on a tight budget on a streetcar its not worth gains to have to buy another set of castings especially pricey 243s. the 241 especially when ported aren't that bad. don't get me wrong i haven't done direct comparisons myself but from others results that is my conclusion. for a reference, i have a bit experience porting heads including 241 and 5.3l heads, unfortunately both my pontiac's heads are uncut.
just my .02
Originally Posted by RE AND CHERYL
Your right. The flow difference between the two is minimal at best. Stock for stock I would choose the 243s, but if your having them ported, I'd start with 241s because they are half the price or less. 5.3 heads are great if you want a 1/2 point more compression without having the cut the heads, they also are dirt cheap.
Re'
yeah i did notice people want some money for the 243s this guy is selling ported 241s for 750 with new double springs on them is that a good deal he says they should flow 270-210 which isn't terrible but not as good as the 243's would.
Old Apr 22, 2009 | 01:11 PM
Droptopws6's Avatar
Thread topic is "Heads on a budget" How about Patriot? I picked up .5 in the quarter mile and 5 mph with cheap, budget, 5.3's , You could time my 60' with a calender too. I went 11.89 @ 117 1.79 60' at 1200' elevation. So, with a dead hook this is sub 11.50 car. Not too bad for new casting heads with dual springs, Ti retainers, 2.02 , 1.57 valves, and ported/polished for 1100.00 bucks. 11.89 was my first run of the season, keep in mind I spin the tires in first and roast them going into second. Hell, I've seen 11.20 slips at 117 mph. People love to bash Patriot stuff, I have no complaints.
Edit: I'm unfamiliar with your cam.
Old Apr 22, 2009 | 04:06 PM
i geuss i should have made this thread porting stock heads because i dont have money to spend on aftermarket heads. and my cam is a TSP torquer version 2 cam it makes real good high end power i ran a 12.3 at 116mph with a 1.95 60' my car wont hook for some reason maybe the track really sucked. if i was going to buy new heads i think i would wait till i have enough for trick flows originaly i posted i wanted to port heads my self which is why i wasnt going to buy heads in the first place
Old Apr 22, 2009 | 04:16 PM
Bad Blue WS6's Avatar
lots of folks dont give the credit that the 241's deserve,,,
https://ls1tech.com/forums/generatio...ls1-heads.html
Old Apr 22, 2009 | 04:20 PM
ABQ99TA's Avatar
If down time is not an issue send your heads to TSP and they will port them for you for less than you think.
Old Apr 22, 2009 | 04:21 PM
i did not know that i will have to ask them so do ported 241s really flow that well?
Old Apr 22, 2009 | 04:39 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
We can set you up with porting on your heads or a new set of GM castings at affordable prices! Of course, the LS6 castings will outperform your 241's once ported, but if it's that much of a budget issue, then it's an option.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Apr 22, 2009 | 08:42 PM
CMR_ls1s's Avatar
^^^what kind of numbers are we talking for the 241s ported and deck milled?flow numbers and $ numbers. And im just curious why a set of ported 243s can out perform the same port job on some 241s? Is the runner design just that different and better, I know the chambers are different.
Old Apr 22, 2009 | 09:32 PM
aren't the valves on the 243s alittle bigger?
Old Apr 22, 2009 | 10:55 PM
ABQ99TA's Avatar
They are the same size valves but that can all be changed when they port. Call TSP they will hook you up.
Old Apr 23, 2009 | 05:37 AM
i pmed them last night i'll see what matt says
Old Apr 23, 2009 | 08:27 AM
  #32
There is a great read on this in the book caled LS1/LS6 Chevy Performance by Chris something or other...theres all kinds of stuff in there, but they also did a test with different casting heads, with different manifolds, etc to do camparisons,,, I want to say the test was done by Agostion racing (?),, anyways,, ported 241's created better flow numbers than the ported 243's up to about the .400 mark, leaving the .500 and .600 marks better on the 243s. Are flow numbers everything?, hell no, but for what you already own, and what little has to be shelled out to make them perform better, it is an option worth checking out. I was trying to find the other threads i had tagged, somw with guys that are running somewhere close to the 10.xx seconds range (i need to find the guy, he's on here) with ported 241's,,
Im no expert, (and really just learning the H/C stuff), but if your cam has a lift of lets just say .550,, would your head flow at .600 even matter? This leads me to believe that for a smaller cam guy or stock cam guy with a lower lift than others with the higher cam lift,, ported 241's might be the way to go to get the best bang for your buck (As like in my case, there are not alot of "bux" to work with to go the 243 route ),,, someone correct me if im way off in my thinking there.
Old Apr 23, 2009 | 09:04 AM
  #33
Jason 98 TA's Avatar
We have a few sets of cnc ported 241 castings available in the stage 1.5 flavor. (2.02 intakes 1.55 ex) without a spring kit they will be sold for $800 a pair!!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Apr 23, 2009 | 09:08 AM
  #34
Jason - do you guys take mine as core?
Old Apr 23, 2009 | 10:15 AM
  #35
All of our heads are sold outright with no core charges. The only reason we ever want your heads is if we are actually porting your castings for you and send them back to you.
__________________
Old Apr 23, 2009 | 10:32 AM
  #36
Thanx!
Old Apr 23, 2009 | 04:39 PM
  #37
yeah i think i am leaning twords ported 241's 243s are to expensive for the heads and then the cnc job and thats a great price on 1.5 heads from tsp. my cam has .598 so i'm looking to get some more flow from my heads plus i would like to put a fast 90/90 and injectors in there..
Old Apr 23, 2009 | 08:14 PM
  #38
CMR_ls1s's Avatar
It is a great book I have it next to me.Just looking through. There is a new book called LS1-LS7 performance parts. It tests aftermarket performance parts and gives dyno sheets with comparisons to stock and competitor parts. Its a great book also.
Old Apr 23, 2009 | 09:15 PM
  #39
yeah i saw that book on amazon so its good what does it talk about before i go and buy it?
Old Apr 24, 2009 | 08:56 AM
  #40
theres tons, heads, cam, induction NA and forced, engine builds, history, all good stuff. That heads article/test was very imformative
By Brett Foote | 2026-06-04 05:00:17
