heads on a budget
i am on a really tight budget and would really like to get some more power out of my tv2 cam and if i buy heads they will be the trick flow's because i dont see any other head that makes close to the power those do but they are 2400 bucks and i also need a bigger intake and injectors
I'll probably catch some fire for this post. oh well.
and thank you for all the responses but i was going to try and port and polish my self i dont even have 1700 dollars to spend plus i like to do my own work and learn how to do things on my car.
would the 243s be a better choice since they may have bigger valves on them? maybe i could deck them to get some more compresson?
Id like to learn to but I just dont know whats best for these heads. Trending Topics
241s have 66cc
243/799s have 64.5cc
See here: http://www.smokemup.com/tech/ls1.php
As for spending $1700 you can get a set of the TFS as-cast heads and get great gains and leave room to have them ported latter, but with aftermarket castings you SHOULD (not have to) use a better aftemarket rockers.
Also check out Loyd Elliot. he does porting of LSx heads for very reasonable rates. I had a set of his heads on my LT1 and they performed as well as heads costing twice as much.
just my .02
just my .02
Re'
