Melling Oil pump or SLP Oil Pump
Old 04-06-2010, 08:18 AM
MJR7AD's Avatar
Default oil pump
I would never put another melling anything in my car. Year and half build and 600 miles on a fully built 383 and my spring breaks in my high volume 296. Know i have to pull it all apart and throw a new one in... pain in the ***. I would go with the slp. Also the company won't even send me a new one or the money back after they sent me a lemon...
Old 04-06-2010, 08:51 AM
Gordon0652's Avatar
Originally Posted by allthrotle
Run the melling hands down.
What he said. I am going to run one in my 440.
SLP is just a glorified company IMO.
Old 04-06-2010, 09:54 AM
355TurboLT1's Avatar
Melling= Chinese garbage. Personally I wouldnt consider either. I would go with a KATECH ported and blueprinted LS6 unit. Katech has been working and winning with the GEN III platform since 97. They flatly know what works in these engines. I get so tired of people here acting like you need all this oil pressure in a stock clearance motor! Take some time and read up on oil and oil systems. It will get you over this high pressure/high volume BS when using factory or close to factory clearances.
Old 04-06-2010, 09:26 PM
BOXCHEV's Avatar
Who has owned both melling 296 or ported ls6?
Sounds like 296 is the winner from most of the replies. Just now looking into lsx motors and looking to build a lq4. I had a ported ls6 on my list of parts to get.
Old 10-17-2010, 02:33 PM
99SS-T's Avatar
Default extra porting?
On thunder racings site they offer the 296 melling with additional porting for 75 bux. Is that something that yall did or just a gimmick? Thanks for the info!
John
Old 10-17-2010, 04:20 PM
Arc00TA's Avatar
I have had both, no problems with either. I chose to run a melling 296 in my current motor since it is older and almost 100k miles. A little extra volume is fine by me. If you spin your motor to high RPM's, I would consider using the low pressure spring as the 296 will empty the pan.
Old 10-18-2010, 12:48 AM
caseypryan's Avatar
Originally Posted by litle88
Melling HANDS DOWN, at start up I get almost 60lbs hot or cold and NEVER moves until it goes WOT and I see nearly 80lbs! Just add 6.25 quarts of oil cause it moves it pretty fast! I have had it on for 3 summers and beaten ALOT with not a hicup!
Just my .o2
This ^
Old 10-18-2010, 12:50 AM
01ssreda4's Avatar
I just recently purchased my second Melling. I ran their standard replacement M295 for a couple of years with no problems. It would push 70 psi from 4k and up.
Old 10-18-2010, 03:53 AM
SS4Luck's Avatar
How hard is it to put an oil pump in? Something that can be done with hand tools in the garage?
Old 10-18-2010, 04:15 AM
lordrazo's Avatar
melling they are the leader in oil pumps !!!
Old 10-18-2010, 07:21 AM
sayed_000's Avatar
milling for sure !
Old 10-18-2010, 07:24 AM
  #32
BODUKE's Avatar
Originally Posted by bigboykilroy
What is the better choice in peoples opinion?
SLP or Melling?
I use a melling pump.
Old 10-18-2010, 07:40 AM
  #33
Atomic02's Avatar
the new mellings are already notched for the double roller chains.
just put one together a couple months ago 60psi steady
Old 10-18-2010, 11:19 AM
  #34
NVR_SPDS's Avatar
It can be done relativly easy. Only specialized tools you'll need are an inch-lb torque wrench, 250+ lb/feet torque wrench, something to lock the flywheel/flexplate and the cam swap gasket set IIRC. Just be damn careful when workin with the pickup tube bolt and o ring.
Old 10-18-2010, 12:50 PM
  #35
Jonnie Bravo's Avatar
Running the SLP and have had no problems yet.
Old 10-18-2010, 12:55 PM
  #36
JustAnotherLS2's Avatar
Originally Posted by djfury05
melling specializes in oil pumps.. jus sayin' =)
This.
Old 10-18-2010, 03:54 PM
  #37
srpoweredcoupeNWH's Avatar
Does that mean you dont have to run the spacers with a double row chain?
Old 10-20-2010, 11:03 AM
  #38
Harley-Davidson88's Avatar
Yeah...I wasn't too impressed with their customer service either. I run a ported LS6 now. This failure took out the LS2 in my GTO.
Old 10-20-2010, 11:20 AM
  #39
Jim_PA's Avatar
GM unless you need the extra oil for a turbo or something.
Quick Reply: Melling Oil pump or SLP Oil Pump
