Melling Oil pump or SLP Oil Pump
Moderator
run the blue spring in the melling - The red spring cause the oil pressure to be to high - if you have a double roller timing chain you will have to clearance the oil pump housing for it to fit.
296 is a high volume and higher pressure pump i think it only comes with the red spring. But looking for more info on people running this pump. I heard really good things about it but like to know more.
