compression test
Old May 3, 2009 | 09:04 AM
99RTA's Avatar
Default compression test
Can someone tell me which relay or fuse to disable so i can crank the engine over with out it starting. I want to test compression in a cylinder.
I have one cylinder that the threads on the spark plug are oily. I think its causing a misfire at idle. The plug doesn't really look fouled though just oily threads. Its number 8. I also notice the engine has a funny knocking noise when it misfires at an idle but only if its in gear. If i give it any throttle the knock goes away??? odd huh?
Old May 3, 2009 | 09:17 AM
Breaking Stuff's Avatar
Pull the fuel pump fuse under the hood. I also pull the ign fuse but Im ****.
Old May 3, 2009 | 09:18 AM
99RTA's Avatar
Thanks...i think the knock i hear is the cylinder unloaded when the plug misfires.
Old Jul 8, 2009 | 11:00 AM
99RTA's Avatar
Pulling both injectors fuses disables everything you need to do a comp test.
Old Jul 8, 2009 | 11:49 AM
SOMbitch's Avatar
Pulling all of your plugs out makes it easier on your starter and give more consistent results.
