Can you use a 6.125 rod in an LQ9 w/ stock stroke?
So I am starting to search around for pistons and rods to forge this LQ9 bottom end before I blow it up. I was looking at the Wiseco book and it says that the aluminum blocks have a 9.240 deck and the iron blocks have a 9.230 deck. The pistons show that with a 6.125 rod and 3.622 the piston will reach 0 deck at 9.240 which would put me .010 out of the hole assuming it doesn't need decked. Is .010 too far out of the hole? The headgasket will be a stock .055 mls. In theory, wouldn't I still have .045 between the piston and the head? The reason that I am trying to use a 6.125 rod is that I have a set available to me. Thanks.
i'd say there are quite a few builds with the pistons .010" out of the hole. i think stock shortblocks stick out quite a bit and my forged 348 stuck out between.006-.008"
you will be be in great shape with .045" clearance as long as your head gasket bore is larger than your piston bore.
OWN3D BY MY PROF!
There's a ton of builds with the pistons out of the hole. Especially when the block has been decked. I just had to change my build with a new set of pistons. The old ones are a 1.1155 CH while the new ones are 1.125. My block has been decked so they are going to stick out quite a bit.
