What are the differences between LS1 and LS6 heads?
Casting Number 853 or 241
LS1
99-00 5.7L Passenger Car and Corvette (853)
01+ 5.7L Passenger Car and Corvette (241)
Material: Aluminum
Combustion Chamber Volume: 66.67cc
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 2.00 inches
Exhaust Valve Diameter: 1.55 inches
Casting Number 243
LS6
01+ 5.7L Corvette
Material: Aluminum
Combustion Chamber Volume: 64.45cc
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
LS1
Material: Aluminum
Casting Number 243
LS6
01+ 5.7L Corvette
Material: Aluminum
Originally Posted by Tin Indian
Looks like you allready have LS6 Stage II heads...
There is a difference in the exhaust ports also right? D-shaped on the LS6 and oval LS1 right?
Thanks for the reply.
Roman
Yes the LS6 heads along with the LQ4, LQ9 heads have D shaped exhaust ports.. They also have raised floors, one of the reasons there is a better gain with the LS6 intake and those heads.. It's practically worthless to put an LS6 intake on stock pre '01 LS1 heads..
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Wait a sec...
There are pretty significant differences besides just the stats provided.
Specifically, the short side radius of the LS6 head is much larger than that of the LS1 head.
could someone anwser the above question is there a difference between the two LS1 Casting #853 & 241. I ask because I have a 2000/SS with the #241 heads, clearly Casted on the passenger side head. Would these heads #241 benefit from a mild home head porting project. Just wondering, sometimes these small issues can effect future mods.
